itk:sim
ITK simulation
This wiki describes the simulation work at ANL focused on single-particle samples (with and without 140 and 200 pileup), and a work on validation of the geometry. The single particle samples created at ANL are discussed here Upgrade Simulation Inner Tracker. The ongoing discussion of how to perform the full simulations can be found in ATLPHYSVAL-385.
Here are a few results obtained using the single-particle samples for the Extended Barrel 4 geometry. They are based on the 1 GeV single particle sample created at ANL Single particle samples
itk/sim.1455230211.txt.gz · Last modified: 2016/02/11 22:36 by asc
