User Tools
Site Tools
itk:extracting_channels_from_root_files
Extracting channels from ROOT files
Overview: The TestAnalysis.py script allows the user of the HSIO to print off specific problematic channels after running a test. The user inputs the root file from the test, the specific histogram they would like to analyze, and must put the maximum number of hits possible in a given channel.
Instructions:
Script:
  #This script allows the user to see the specific ouput for specific pixels on different electronic tests
  from ROOT import *
  #The user must input the root file, histogram, and the maximum number for bin content
  fileName = "path/to/file.root"
  histogramName = "name of histogram"
  maxValBin = 50
  #Do not modify the rest of the code, it should work given what the user has place above.
  test = TFile.Open(fileName)
  h = test.Get(histogramName)
  h.Draw("colz")
  for i in range(1, h.GetNbinsX()):
        for j in range(1, h.GetNbinsY()):
        binContent = h.GetBinContent(i, j)
        if binContent < maxValBin:
              print "*****************************"
              print "Pixel column (x): ", i
              print "Pixel row (y): ", j
              print "Number of hits: ", binContent
itk/extracting_channels_from_root_files.1473963892.txt.gz · Last modified: 2016/09/15 18:24 by mbeydler
