This testbeam is planned in Fermilab https://web.fnal.gov/experiment/FTBF/Mtest/2017_Schedule.aspx using 120 GeV protons. The main goal of this testbeam is to test HVCMOS pixel sensors. The University of Geneva provides the telescope, DAQ and technical expertise to set it up and use it.
<fc #FF0000>Read the Testbeam Manual before and during your shift!</fc>
A outline of the sample test schedule is here https://docs.google.com/spreadsheets/d/1Uv5hGlnCU5rnV7FzXFXE4O0cko_fOGiu8kYgUpBxdu8/edit#gid=876192247
A living document for operating the telescope can be found here: https://docs.google.com/document/d/1c0UE1NvmkBhJ4uaZUzRNWKqHAOI5j43DbJwnIyXC7yM/edit
Updated Last: Apr 4 10:00pm
Taking data. We have cooling system “working”. Would still like to understand the humidity more. Some of the samples have been taking to irradiations.
<fc #FF0000>*Any change of the test setup (mainly equipments) in the beam area need electric investigation before power on</fc>
Equipment available from HEP/ANL:
In addition to the HSIO2 Linux setup, ANL has alternative system based on Windows10 with usbPix from Bonn (can be used to check HSIO2 results)
Equipment available from U.Geneva:
Telescope setup here
General rce software here on gitlab rce software used for Fermilab testbeam here UGen rce software here
<fc #FF0000>ANL shift information:</fc>
Currently, 3 modules are being tested:
<fc #FF0000>UGen shift informations:</fc>
Schedule and run list UniGe Shifter Schedule Fermilab Test Beam Schedule Testbeam Hall
*Detailed information and schedule can be found on Geneva group testbeam Twiki page https://twiki.cern.ch/twiki/bin/view/GeneveAtlas/TB2017_Fermilab
Software for Geneva testbeam data reconstruction:
https://gitlab.cern.ch/unige-fei4tel/proteus
Also I downloaded one copy to Argonne which has been compiled and ready to use:
/users/rwang/ITK/PIX/TestBeam/proteus
*Tag version is expected by this week on git and testbeam computer
The data is being exported to the eos file system here: /eos/atlas/atlascerngroupdisk/pixel-upgrade/itk/BeamTest/fermilab_2017_march_fei4tel For information on updating the data from fermilab local files see 'Backup on EOS': https://twiki.cern.ch/twiki/bin/viewauth/GeneveAtlas/TB2017_Fermilab
For information on using the eos filesystem and mounting: https://twiki.cern.ch/twiki/bin/view/TOTEM/CompEOS https://twiki.cern.ch/twiki/bin/view/EOS/UserHowTo
There is a working proteus distro at : /afs/cern.ch/user/d/dfrizzel/proteus/
Analysis code with Fermilab beam configuration can be found at: /afs/cern.ch/user/d/dfrizzel/pixelAnalysis/analysis
Preliminary results of this code can be found at : /afs/cern.ch/work/d/dfrizzel/public/pixelAnalysis/output
Can also be obtained from gitlab instructions found at : https://twiki.cern.ch/twiki/bin/view/Main/ProteusSw
Proteus is built by University of Geneva on top of the Judith framework to analyze testbeam data.
Test runs and scripts can be found under test/. To run the full reconstruction for Run 1066, do:
./run_dut0_noisescan.sh 1066 <fc #0000FF>#Should this be ./run_all.sh 1066 ?</fc>
Data is stored locally in FNAL_2017/raw
Data is stored globally at /eos/atlas/atlascerngroupdisk/pixel-upgrade/itk/BeamTest/fermilab_2017_march_fei4tel Use the eosmount system to browse.
Run 438: Green RTI module(sub-optimal config): threshold 2000: HV 80: 90 degrees: 5M events. Protons 120GeV
Run 444: Green RTI module (best config-see work log Mar 11,3:00pm): threshold 2000: HV 80:90 degrees: 5M events. Protons 120GeV
Run 447: Green RTI module (re-tuned config, same as 444): threshold 2000: HV 80: 90 degrees: 5M events. Protons 120GeV
Run 475: Green RTI module HV 80: threshold 1500: 90 degrees: 5M events. 120GeV protons.
ALL FURTHER RUNS ARE LISTED IN LOG BELOW (TOO MUCH DATA TO LIST)
A full run list can be found at: https://docs.google.com/spreadsheets/d/16MLvwoQjqk7z-lO46e-O_PYlztVLbwufYjr6TlXAAmk/edit#gid=1421580169
Grounding issue
1. The LV and HSIO 1/2 board need share same grounding. Otherwise error words and timeout message will appear on the caliserver side. Grounds for communicating devices should be grounded in a common location on the grounding bus (ex: two chips should be close together on a circuit board and be grounded in a similar place).
2. Moving the LV from floating ground using weiner PS to fixed ground increase the efficiency from 20-30 hits to 40-60 hits in analog scan.
3. The HV grounding pins need to be connected on the SCC!!
4. For good wifi access visit https://fermi.service-now.com/kb_view_customer.do?sysparm_article=KB0010655 . this will allow you to register a personal computer for the fgz wifi.
5. The masking of pixels is constructed exclusively by the noisescans. If there is a masking issue look here first. If issue persists the HSIO2 can manually mask pixels from the config tab.
6. The Primlist will fail if a run number has been previously used and it must ask permission to over-write.
7. Sometimes communication issues can arise due to insufficient power. If scans or tunings seem to fail randomly at some point throughout the scan(s), make sure the LV supply is adequate during scanning.
8. If the h35demo has difficulty communicating with calibGui you can try a similar fix to #7 by adjusting the VDDA on the Caribou.
9. If you see a strange pattern in the mask during data taking. Retune the fei4 in-situ. This has worked thus far.
The current COMM note is shown in: https://svnweb.cern.ch/trac/atlasinst/browser/Institutes/ANL/ITK/note_testbeam2017feb/trunk
Get the note as:
svn co svn+ssh://svn.cern.ch/reps/atlasinst/Institutes/ANL/ITK/note_testbeam2017feb/trunk note_testbeam2017feb
The current setup (March 24, 2017) looks as this:
Requires the flowing figures in the EPS format plus ROOT files. Please attach these ROOT files to this wiki. Standard 3000e threshold.
Make figures BEFORE calibration WITHOUT the bias -80 V. No BEAM:
Make figures AFTER the calibration WITHOUT -80 V applied. NO BEAM:
Make figures BEFORE calibration WITH -80 V applied. No BEAM:
Make figures AFTER calibration WITH -80 V applied. NO BEAM:
These plots can be found on argon servers here:
/users/dfrizzell/RTI_SCANS
Plots for 120 GeV protons. The module should be calibrated to 3000e without the BEAM.
BEAM is ON:
The module should be calibrated to 3000e.
Same plot should be obtained after irradiation (if we can)
<fc #FF0000>Please find and insert the shift log here</fc>
