lcrc:introduction [2022/01/05 15:49] asc [Using interactive jobs] |
lcrc:introduction [2023/06/15 14:05] rwang [Using interactive jobs] |
Line 165: | Line 165: | ||
- | but the job will stop after you logout. See more description in: https:// | ||
+ | === Running long interactive jobs === | ||
+ | See more description in: https:// | ||
+ | You should be able to do for example: | ||
+ | -ssh bebop | ||
+ | -screen | ||
+ | -salloc -N 1 -p hepd -A condo -t 96:00:00 | ||
+ | -ssh < | ||
+ | -Work on interactive job for x amount of time... | ||
+ | -Disconnect from screen (different than exit, see the documentation) | ||
+ | -Logout | ||
+ | -Login to the same login node screen was started on | ||
+ | -screen -ls | ||
+ | -Connect to screen session | ||
+ | -Continue where you left off (if they allocation is still active) | ||
+ | See below for more details: | ||
+ | https:// | ||
+ | https:// | ||
+ | ====== CVMFS repositories ====== | ||
+ | Mounted CVMFS repositories on Bebop and Swing computing node. | ||
+ | Note, they are not mounted on login nodes | ||
====== Using Singularity ====== | ====== Using Singularity ====== | ||
Line 198: | Line 247: | ||
- | --- // | + | ====== Using Singularity for cvmfsexec ====== |
+ | One can also setup cvmf on any LCRC nodes as this: | ||
+ | source / | ||
+ | Then check: | ||
+ | ls /cvmfs/ | ||
+ | You will see the mounted directory (SL7): | ||
+ | atlas-condb.cern.ch/ | ||
+ | atlas-nightlies.cern.ch/ | ||
