lcrc:introduction [2022/01/24 16:34] asc [Using interactive jobs] |
lcrc:introduction [2023/06/15 14:05] rwang [Using interactive jobs] |
Line 172: | Line 172: | ||
You should be able to do for example: | You should be able to do for example: | ||
- | <codde> | + | <code> |
-ssh bebop | -ssh bebop | ||
-screen | -screen | ||
Line 196: | Line 196: | ||
+ | ====== CVMFS repositories ====== | ||
+ | Mounted CVMFS repositories on Bebop and Swing computing node. | ||
+ | Note, they are not mounted on login nodes | ||
====== Using Singularity ====== | ====== Using Singularity ====== | ||
Line 228: | Line 247: | ||
- | --- // | + | ====== Using Singularity for cvmfsexec ====== |
+ | One can also setup cvmf on any LCRC nodes as this: | ||
+ | source / | ||
+ | Then check: | ||
+ | ls /cvmfs/ | ||
+ | You will see the mounted directory (SL7): | ||
+ | atlas-condb.cern.ch/ | ||
+ | atlas-nightlies.cern.ch/ | ||
