phase2:led [2015/07/17 18:49] asc |
phase2:led [2015/09/30 15:07] (current) asc |
Line 1: | Line 1: | ||
====== TileCal LED tests ====== | ====== TileCal LED tests ====== | ||
- | Here is a data library with PMT signals with different attenuators. The dynamic rage is from 1 pC to 2000 pC. | + | Here is a data library with PMT signals with different attenuators. |
+ | The dynamic rage is from 1 pC to 2000 pC. The data are collected using R5900 PMT with active dividers and 676 V, and a WLS fibre, Patrick' | ||
+ | with 4 ns pulse width and David' | ||
- | The data are collected using R5900 PMT with active dividers | + | The talk that describes this study is [[https:// |
- | Download | + | Download |
- | To make a plot for 1 trace, use | + | |
wget --no-check-certificate https:// | wget --no-check-certificate https:// | ||
cd pmt_signals_phase2/ | cd pmt_signals_phase2/ | ||
- | python show_trace.py data/ | + | python show_trace.py data/ |
- | We used 1 neutral density filter | + | We used several |
- | Data files with traces are in " | + | Data files with traces are in " |
+ | The file names has a letter " | ||
- | - D1 NDF16 + 6xNDF50 | + | - D1 NDF16 + 6xNDF50. Reduction of light by 6*2*16. About 0.3 pc -> x1024 |
- | - D2 NDF16 + 5xNDF50 | + | - D2 NDF16 + 5xNDF50 |
- | - D3 NDF16 + 4xNDF50 | + | - D3 NDF16 + 4xNDF50 |
- | - D4 NDF16 + 3xNDF50 | + | - D4 NDF16 + 3xNDF50 |
- | - D5 NDF16 + 2xNDF50 | + | - D5 NDF16 + 2xNDF50 |
- | - D6 NDF16 + 1xNDF50 | + | - D6 NDF16 + 1xNDF50 |
- | - D7 NDF16 | + | - D7 NDF16 |
- | - D8 3xNDF50 | + | - D8 3xNDF50 |
- | - D9 2xNDF50 | + | - D9 2xNDF50 |
- | - D10 1xNDF50 | + | - D10 1xNDF50 |
- | - D11 - no NDF | + | - D11 - no NDF. About 2000 pC ->0 |
- | All figures | + | Figures |
+ | Blue lines show traces before the noise removal, and small grey dots after the noise suppression. The green dots show the noise in the LED driver. | ||
