snowmass2013:montecarlo [2013/06/28 11:05] asc |
snowmass2013:montecarlo [2014/10/04 13:31] asc |
Line 6: | Line 6: | ||
[[http:// | [[http:// | ||
- | * [[https:// | + | * [[https:// |
* 14 TeV pp collision energy. | * 14 TeV pp collision energy. | ||
- | * The Snowmass detector geometry [[http://atlaswww1.hep.anl.gov/ | + | * The Snowmass detector geometry [[http://mc.hep.anl.gov/ |
* PFlow jets with jet area correction. | * PFlow jets with jet area correction. | ||
* Each sample is generated for **< | * Each sample is generated for **< | ||
- | One can view and browser directories with all simulated samples using the [[http://atlaswww1.hep.anl.gov/ | + | One can view and browser directories with all simulated samples using the [[http://mc.hep.anl.gov/ |
Here is a detailed description: | Here is a detailed description: | ||
Line 20: | Line 20: | ||
- **[[snowmass2013: | - **[[snowmass2013: | ||
- | - **[[snowmass2013: | ||
Line 57: | Line 56: | ||
Truth MC record was removed from the Delphes files to reduce file size. Below you can find a repository with truth MC information: | Truth MC record was removed from the Delphes files to reduce file size. Below you can find a repository with truth MC information: | ||
- | **[[snowmass2013: | + | **[[snowmass2013: |
+ | **[[http:// | ||
===== Help for analyzers==== | ===== Help for analyzers==== | ||
Line 83: | Line 83: | ||
===== ATLAS-like detector ===== | ===== ATLAS-like detector ===== | ||
- | [[http://atlaswww1.hep.anl.gov/ | + | [[http://mc.hep.anl.gov/ |
===== Other samples ===== | ===== Other samples ===== | ||
Line 99: | Line 99: | ||
