User Tools
Site Tools
snowmass2013:montecarlo
Differences
Link to this comparison view
Next revision
Previous revision
snowmass2013:montecarlo [2013/07/25 15:28]
asc
snowmass2013:montecarlo [2015/05/12 20:10] (current)
asc
Line 1: Line 1:
 +<note important>This page was created during the DPF2013 studies. All truth-level MC samples have been moved to
 +[[http://atlaswww.hep.anl.gov/hepsim/ | the HepSim Monte Carlo repository]]
 +</note>
Line 8: Line 12:
   * [[https://cp3.irmp.ucl.ac.be/projects/delphes | Delphes 3.09]]. Use  Delphes 3 reference [[http://arxiv.org/abs/1307.6346]]   * [[https://cp3.irmp.ucl.ac.be/projects/delphes | Delphes 3.09]]. Use  Delphes 3 reference [[http://arxiv.org/abs/1307.6346]]
   * 14 TeV pp collision energy.   * 14 TeV pp collision energy.
-  * The Snowmass detector geometry [[http://atlaswww1.hep.anl.gov/asc/snowmass2013/delphes36/?dir=packages | See "updateMay8" input cards]]+  * The Snowmass detector geometry [[http://mc.hep.anl.gov/asc/snowmass2013/delphes36/?dir=packages | See "updateMay8" input cards]]
   * PFlow jets with jet  area correction.   * PFlow jets with jet  area correction.
   * Each sample is generated for **<mu>=0,50,140 pileup** pileup scenarios (soft events are generated with HERWIG++)   * Each sample is generated for **<mu>=0,50,140 pileup** pileup scenarios (soft events are generated with HERWIG++)
-One can view and browser directories with all simulated samples using the [[http://atlaswww1.hep.anl.gov/asc/snowmass2013/delphes36/| ANL Monte Carlo repository]]. +One can view and browser directories with all simulated samples using the [[http://mc.hep.anl.gov/asc/snowmass2013/delphes36/| ANL Monte Carlo repository]].
 Here is a detailed description: Here is a detailed description:
Line 56: Line 60:
 Truth MC record was removed from the Delphes files to reduce file size. Below you can find a repository with truth MC information: signal, signal+pileup (<mu>=50) and signal+pileup(<mu>=140). Pileup particles are included. Truth MC record was removed from the Delphes files to reduce file size. Below you can find a repository with truth MC information: signal, signal+pileup (<mu>=50) and signal+pileup(<mu>=140). Pileup particles are included.
-**[[snowmass2013:montecarlo_truth | Repository with truth MC information]]** <fc #FF0000>New</fc>+**[[snowmass2013:montecarlo_truth | Repository with truth MC information]]**
 +**[[http://atlaswww.hep.anl.gov/hepsim/ | HepSim Repository with Monte Carlo predictions for HEP]]** <fc #FF0000>New</fc>
 ===== Help for analyzers==== ===== Help for analyzers====
Line 82: Line 87:
 =====  ATLAS-like detector ===== =====  ATLAS-like detector =====
-[[http://atlaswww1.hep.anl.gov/asc/snowmass2013/atlas/ | Here ]] are the samples for ATLAS-like fast simulation using Delphes 3.03 without pileup removal.+[[http://mc.hep.anl.gov/asc/snowmass2013/atlas/ | Here ]] are the samples for ATLAS-like fast simulation using Delphes 3.03 without pileup removal.
 =====  Other samples ===== =====  Other samples =====
Line 98: Line 103:
  --- //[[[email protected]|Sergei Chekanov]] 2013/03/06 20:47//  --- //[[[email protected]|Sergei Chekanov]] 2013/03/06 20:47//
 --- //[[[email protected]|Alexandre Vaniachine]] 2013/03/06 20:47// --- //[[[email protected]|Alexandre Vaniachine]] 2013/03/06 20:47//
snowmass2013/montecarlo.1374766081.txt.gz · Last modified: 2013/07/25 15:28 by asc
