tier3_admin:tier3admin_data
Data Distribution
Currently data is located in /data1 and /data2 on atlas50-65. If a user asks about data distribution, follow these steps:
- Copy these 2 scripts to your directory from
/users/chakanau/public/Arcond/data_distribute
- hosts.py - keeps host names
- arc_sync - the actual script to sync data to remote hosts
- Look at “arc_sync”. Here you will need to specify 2 variables:
OriginalLocation - the original location of the data USER - your user name
You will also need to specify the directory structure for this dataset on the farm. For example:
SetLocation="/data2" SetName="mc11_7TeV" SetType="113210.HerwigppJetsJ6.merge.NTUP_JETMET" SetVersion="e835_s1309_s1300_r3043_r2993_p839"
- Run the script. You may need to change the permisions on the remote host to be abale to copy the data.
- To remove the data, use the “arc_rm” command (Be sure to specify the location of the data on the farm!).
tier3_admin/tier3admin_data.txt · Last modified: 2013/05/30 18:53 by 127.0.0.1
