tier3_admin:tier3cvmfs
Table of Contents
Installation of CVMFS
- The official ATLAS documentation for installation of CVMFS client can be found at this reference.
- The official CVMFS documentation can be found at this reference.
Read: https://twiki.cern.ch/twiki/bin/view/Atlas/Tier3CVMFS2SLC5
ANL-specific details
- The cache area is located in /home/cache/cvmfs2. The path variable in the ATLAS documentation is home
- /home/cache/cvmfs2 should be owned by the cvmfs account
- Only 25 GB of space is needed
- The cvmfs account will be created in the /etc/passwd file.
cvmfs:x:383:384:CernVM-FS service account:/var/cache/cvmfs2:/sbin/nologin
Local Configuration details
In this section the specific configuration details for ANL will be listed.
- Edit (create if it does not exist) the file /etc/cvmfs/default.local, in particular, change
CVMFS_REPOSITORIES=atlas.cern.ch,atlas-condb.cern.ch,atlas-nightlies.cern.ch CVMFS_CACHE_BASE=/home/cache/cvmfs2 CVMFS_QUOTA_LIMIT=13000 CVMFS_HTTP_PROXY="http://squid.hep.anl.gov:3128;DIRECT"
- Create a file /etc/cvmfs/domain.d/cern.ch.local and add the following entry:
# Change the order so that the nearest server is the first in the list ... # Note that port 8000 is preferred for the servers below but, if it does not work, use port 80 instead. # if you are in North America (uncomment) CVMFS_SERVER_URL="http://cvmfs.racf.bnl.gov:8000/opt/@org@;http://cvmfs-stratum-one.cern.ch:8000/opt/@org@;http://cernvmfs.gridpp.rl.ac.uk:8000/opt/@org@"
- Add cvmfs to chkconfig
/sbin/chkconfig --levels 345 cvmfs on
- Restart cvmfs
/sbin/service cvmfs restart
- Check if cvmfs works, by inspecting the contents of the following directories:
> ls /cvmfs/atlas.cern.ch/ repo > ls /cvmfs/atlas.cern.ch/repo ATLASLocalRootBase conditions sw > ls /cvmfs/atlas-condb.cern.ch/repo conditions tag
Start and stop cvmfs
- Start
/sbin/service cvmfs start
- Stop
/sbin/service cvmfs stop
How to install on SL6.4
For SL6, do this:
yum install compat-expat1 openssl098e libuuid-devel rpm -Uvh http://cvmrepo.web.cern.ch/cvmrepo/yum/cvmfs/EL/6/x86_64/cvmfs-release-2-4.el6.noarch.rpm yum install cvmfs cvmfs-init-scripts cvmfs-auto-setup
Doug suggestions (no need!):
yum install libuuid-devel ln -s /lib64/libuuid.so.1 /lib64/libuuid.so wget http://linuxsoft.cern.ch/cern/slc6X/extras/x86_64/RPMS/HEP_OSlibs_SL6-1.0.7-0.el6.x86_64.rpm yum install HEP_OSlibs_SL6-1.0.7-0.el6.x86_64.rpm
Then put ANL specific files (take from atlas17)
scp [email protected]:/etc/cvmfs/domain.d/cern.ch.local /etc/cvmfs/domain.d/ scp [email protected]:/etc/cvmfs/default.local /etc/cvmfs/
and restart it
tier3_admin/tier3cvmfs.1376405334.txt.gz · Last modified: 2013/08/13 14:48 by asc
