tier3_admin:tier3squid
Table of Contents
Installation instructions for SQUID proxy cache
If needed, the official CERN instructions for this installation are available.
After you login as root, follow these steps carefully:
- Create the squid user and squid group
groupadd squid useradd -g squid -d /var/cache/squid -s /sbin/nologin squid
- Mount the partition /var/cache/squid
- Make the partition owned by squid
chown squid:squid /var/cache/squid
- Install the yum repository from CERN
wget -O /etc/yum.repos.d/cern-frontier.repo http://frontier.cern.ch/dist/rpms/cern-frontier.repo
- Check to see if you can see the repository:
yum list frontier-squid
- Install the frontier-squid package
yum install frontier-squid
Local configuration steps
- The file: /etc/squid/customize.sh must be modified before the squid cache server is started.
- Change the line:
setoption("acl NET_LOCAL src", "10.0.0.0/8 172.16.0.0/12 192.168.0.0/16")to be:
setoption("acl NET_LOCAL src", "146.139.52.0/24 146.139.180.0/25 146.139.30.0/25 146.139.116.0/25 130.202.8.0/24 130.202.237.0/25 130.202.173.0/25 146.139.33.0/25 130.202.96.0/22 130.202.24.0/22 130.202.134.0/24 130.202.131.0/24")
- The firewall for the squid server should have port 3128 opened :
- Add to file /etc/sysconfig/iptables the line:
-A INPUT -m state --state NEW -m tcp -p tcp --dport 3128 -j ACCEPT
- Remember the squid server will only serve requests from network masks as listed in customize.sh
- Restart iptables
/sbin/service iptables restart
- Restart squid server
/sbin/service frontier-squid restart
Testing the squid server
Starting/ stopping Squid server
- Start the server
/sbin/service frontier-squid start
- Stop the server
/sbin/service frontier-squid stop
- Turn on runlevels 3, 4, and 5:
/sbin/chkconfig --levels 345 frontier-squid on
tier3_admin/tier3squid.txt · Last modified: 2015/04/13 16:49 by dbenjamin
