Read: https://twiki.cern.ch/twiki/bin/view/Atlas/Tier3CVMFS2SLC5
cvmfs:x:383:384:CernVM-FS service account:/var/cache/cvmfs2:/sbin/nologin
In this section the specific configuration details for ANL will be listed.
CVMFS_REPOSITORIES=atlas.cern.ch,atlas-condb.cern.ch,atlas-nightlies.cern.ch CVMFS_CACHE_BASE=/home/cache/cvmfs2 CVMFS_QUOTA_LIMIT=13000 CVMFS_HTTP_PROXY="http://squid.hep.anl.gov:3128;DIRECT"
# Change the order so that the nearest server is the first in the list ... # Note that port 8000 is preferred for the servers below but, if it does not work, use port 80 instead. # if you are in North America (uncomment) CVMFS_SERVER_URL="http://cvmfs.racf.bnl.gov:8000/opt/@org@;http://cvmfs-stratum-one.cern.ch:8000/opt/@org@;http://cernvmfs.gridpp.rl.ac.uk:8000/opt/@org@"
/sbin/chkconfig --levels 345 cvmfs on
/sbin/service cvmfs restart
> ls /cvmfs/atlas.cern.ch/ repo > ls /cvmfs/atlas.cern.ch/repo ATLASLocalRootBase conditions sw > ls /cvmfs/atlas-condb.cern.ch/repo conditions tag
/sbin/service cvmfs start
/sbin/service cvmfs stop
For SL6, do this:
yum install compat-expat1 openssl098e libuuid-devel rpm -Uvh http://cvmrepo.web.cern.ch/cvmrepo/yum/cvmfs/EL/6/x86_64/cvmfs-release-2-3.el6.noarch.rpm yum install cvmfs cvmfs-init-scripts cvmfs-auto-setup
Doug suggestions (no need!):
yum install libuuid-devel ln -s /lib64/libuuid.so.1 /lib64/libuuid.so wget http://linuxsoft.cern.ch/cern/slc6X/extras/x86_64/RPMS/HEP_OSlibs_SL6-1.0.7-0.el6.x86_64.rpm yum install HEP_OSlibs_SL6-1.0.7-0.el6.x86_64.rpm
Then put ANL specific files (take from atlas17)
/etc/cvmfs/domain.d/cern.ch.local /etc/cvmfs/default.local
and restart it
