Both sides previous revision
Previous revision
Next revision
Previous revision
fcs:fccee:setup [2023/04/03 14:41] hepsim17 [Setting up the computer environment] |
fcs:fccee:setup [2023/04/10 12:25] (current) hepsim17 [Setting up the computer environment] |
====== Setting up the computer environment ====== | ====== Setting up the computer environment ====== |
| The FCC-ee software tutorial for the [[https://www.bnl.gov/usfccworkshop/| FCC-ee BNL workshop (April 24–26, 2023)]] requires a SSH login to a computer with CVMFS installed. For SSH, use a Linux computer, or a Windows computer with WSL or PuTTY, or cygwin. |
The FCC-ee software tutorial for the [[https://www.bnl.gov/usfccworkshop/| FCC-ee BNL workshop (April 24–26, 2023)]] requires a Linux computer with the mounted CVMFS (/cvmfs/sw.hsf.org/key4hep/). This key4hep directory includes the C++ compiler and various external C++ libraries. If you do not plan to install the CVMFS pointed to the CERN libraries on your personal computer, use the following interactive nodes with ssh logins: | The computer with mounted CVMFS should access /cvmfs/sw.hsf.org/key4hep/. This key4hep directory includes the C++ compiler and various external C++ libraries. If you do not plan to install the CVMFS pointed to the CERN libraries on your personal computer, use the following interactive nodes with ssh logins: |
* ** lxplus.cern.ch** - for people associated with CERN and having the CERN computer accounts. | * ** lxplus.cern.ch** - for people associated with CERN and having the CERN computer accounts. |
* Members from the ATLAS/CMS and other collaborations can use their Tier3 computers with CVMFS. | * Members from the ATLAS/CMS and other collaborations can use their Tier3 computers with CVMFS. |
* ** BNL participants** can use [[NEED SOME TEXT]] | * **OSG interactive nodes** can be used by all other participants who cannot use the options mentioned above. The OSG resource is available for the USA participants associated with US universities and laboratories. |
* **OSG interactive nodes** can be used by all other participants who cannot use the options mentioned above. These resources are available for the USA participants associated with US universities and laboratories. | |
===== How to get the OSG account ===== | ===== How to get the OSG account ===== |
If you are already associated with a USA institution, use this [[ https://www.osgconnect.net/]] link to sign-up. During the sign-up, request the project **osg.FutureColliders** (Sergei Chekanov is the project PI). Then you will be explained how to obtain the account. This project typically uses the "login05.osgconnect.net" interactive node. This note links the /cvmfs/sw.hsf.org/key4hep/ which will be needed for this tutorial. | If you are associated with a USA institution and would like to use the OSG account, use [[ https://www.osgconnect.net/]] link to sign-up. During the sign-up, request the project **osg.FutureColliders** (Sergei Chekanov is the project PI). Then you will be explained how to obtain the account. This project typically uses the "login05.osgconnect.net" interactive node. This note links the /cvmfs/sw.hsf.org/key4hep/ which will be needed for this tutorial. |
