Setting up the computer environment
The FCC-ee software tutorial for the FCC-ee BNL workshop (April 24–26, 2023) requires a SSH login to a computer with CVMFS installed. For SSH, use a Linux computer, or a Windows computer with WSL or PuTTY, or cygwin.
The computer with mounted CVMFS should access /cvmfs/sw.hsf.org/key4hep/. This key4hep directory includes the C++ compiler and various external C++ libraries. If you do not plan to install the CVMFS pointed to the CERN libraries on your personal computer, use the following interactive nodes with ssh logins:
  • lxplus.cern.ch - for people associated with CERN and having the CERN computer accounts.
  • Members from the ATLAS/CMS and other collaborations can use their Tier3 computers with CVMFS.
  • OSG interactive nodes can be used by all other participants who cannot use the options mentioned above. The OSG resource is available for the USA participants associated with US universities and laboratories.
How to get the OSG account
If you are associated with a USA institution and would like to use the OSG account, use https://www.osgconnect.net/ link to sign-up. During the sign-up, request the project osg.FutureColliders (Sergei Chekanov is the project PI). Then you will be explained how to obtain the account. This project typically uses the “login05.osgconnect.net” interactive node. This note links the /cvmfs/sw.hsf.org/key4hep/ which will be needed for this tutorial.
BNL FCC-ee workshop organizers
