hepsim:usage
Differences
— | hepsim:usage [2024/07/01 21:25] (current) – created - external edit 127.0.0.1 | ||
Line 1: | Line 1: | ||
+ | {{indexmenu_n> | ||
+ | ====== Analyzing events ====== | ||
+ | The Monte Carlo files (truth level, fast simulations and full simulations) | ||
+ | can be accessed from the [[http:// | ||
+ | Currently these studies are based on [[http:// | ||
+ | Geometry files for full detector simulations can be found in the [[http:// | ||
+ | You have several choices for data analysis: | ||
+ | * Using the hs-tools package. It is designed for downloading files and processing truth-level files using Python/ | ||
+ | * Using [[http:// | ||
+ | * Using C++/ROOT. If you run over ProMC (truth-level) files, look at the manual [[https:// | ||
+ | * If you run over ROOT files from Delphes, use [[https:// | ||
+ | * If you analyse LCIO files with full simulation, look at [[http:// | ||
+ | Some analysis examples implemented in Python and C++ can be found in [[fcs: | ||
+ | * [[https:// | ||
+ | * [[http:// | ||
+ | Every entry in the HepSim has " | ||
+ | by the fast simulation program (Delphes) have the tag " | ||
+ | If you need to find all samples for a given tag, use the [[http:// | ||
+ | For example, if you are searching for the " | ||
+ | Here are several links to extending this Wiki for particular detector-performance topics: | ||
+ | * [[fcs: | ||
+ | * [[fcs: | ||
+ | * [[fcs: | ||
+ | * [[fcs: | ||
+ | * [[vlhc: | ||
+ | This manual describes how to work with truth-level samples posted on HepSim. | ||
+ | [[https:// | ||
