Analyzing events
The Monte Carlo files (truth level, fast simulations and full simulations) can be accessed from the HepSim repository link. Currently these studies are based on Jas4pp data-analysis environment. Geometry files for full detector simulations can be found in the detector repository.
You have several choices for data analysis:
- Using the hs-tools package. It is designed for downloading files and processing truth-level files using Python/Jython scripts (or using Java)
- Using Jas4pp. It is similar to the above package, but it has packages needed to process full-simulation samples (SLCIO files).
- Using C++/ROOT. If you run over ProMC (truth-level) files, look at the manual ProMC manual.
- If you run over ROOT files from Delphes, use Delphes manual. Note that Delphes ROOT files can be processed using Java Jas4pp program.
- If you analyse LCIO files with full simulation, look at LCIO manual.
Some analysis examples implemented in Python and C++ can be found in here. Here are more resources:
- https://github.com/hepsim-org/analysis - shows analysis examples illustrating how to read ProMC and LCIO files.
- ProMC validation - lists examples that read ProMC files. The examples are implemented in Jython/Python. They can be converted to Java.
- LCIO validation - lists examples that read LCIO files. The examples are implemented in Jython/Python. They can be converted to Java.
Finding detector simulations
Every entry in the HepSim has “truth-level” files (created by Monte Carlo generators) and reconstruction tags: Data after processing by the fast simulation program (Delphes) have the tag “rfastNNN” (NNN is a number), while data after full simulation have the tag “rfullNNN” (NNN is a number). The info pages for each sample has the link to the tag and the information page describing the detector.
If you need to find all samples for a given tag, use the search page. Then type the tag name. For example, if you are searching for the “rfull006” reconstruction tag, this page returns a complete list of Monte Carlo samples which were processed for a given detector.
Physics and detector studies
Here are several links to extending this Wiki for particular detector-performance topics:
- FCC-hh detector studies - explains how to analyses data for FCC-hh detector studies
- SID detector studies - explains how to analyses data for the SiD detector (ILC)
- CEPC detector studies - shows some results with full simulations for CEPC
- EIC detector studies - shows some results with full simulations for EIC
- HCAL studies explains how to analyse ROOT data after fast detector simulations used for FCC studies
This manual describes how to work with truth-level samples posted on HepSim. HepSim Python/Java analysis page explains how to write code to read truth-level files using Python on the Java platform.
— Sergei Chekanov 2016/04/27 11:37
