Differences
Link to this comparison view
Next revision
Previous revision
fcs:fccee:tutorial [2023/04/10 14:36]
hepsim17 [Validation]
fcs:fccee:tutorial [2023/05/24 14:06] (current)
hepsim17 [Data streaming]
Line 74: Line 74:
 Click the tab below to see the code. This code may look rather long, but it does a lot: It reads the truth-level events, reconstructs jets, and makes plots of the pT (differential cross section), Rapidity distribution and the invariant mass of the 2 jets. It also saves the image in SVG file  and an XML file for examination: Click the tab below to see the code. This code may look rather long, but it does a lot: It reads the truth-level events, reconstructs jets, and makes plots of the pT (differential cross section), Rapidity distribution and the invariant mass of the 2 jets. It also saves the image in SVG file  and an XML file for examination:
-<hidden> +<hidden Click here to show the Python/Jython code
-<code python>+<code>
 # Part of =HepMC= : https://atlaswww.hep.anl.gov/asc/hepsim/ # Part of =HepMC= : https://atlaswww.hep.anl.gov/asc/hepsim/
 # S.Chekanov (ANL) # S.Chekanov (ANL)
Line 105: Line 105:
 cross=0; nev=0;  # Nfiles=len(flist) cross=0; nev=0;  # Nfiles=len(flist)
 for m in range(Nfiles):             # loop over all files in this list     for m in range(Nfiles):             # loop over all files in this list
-   file=FileMC(url+flist[m])        # get input file+   file=FileMC(flist[m])        # get input file
    header = file.getHeader()    header = file.getHeader()
    un=float(header.getMomentumUnit()) # conversion units    un=float(header.getMomentumUnit()) # conversion units
Line 123: Line 123:
            py=pa.getPy(j)/un         # pY            py=pa.getPy(j)/un         # pY
            pz=pa.getPz(j)/un         # pZ            pz=pa.getPz(j)/un         # pZ
-           e= pa.getEnergy(j)/un     # energy+           e= pa.getEnergy(j)/un        # energy
            mass= pa.getMass(j)/un    # mass            mass= pa.getMass(j)/un    # mass
            apdg=abs(pa.getPdgId(j))            apdg=abs(pa.getPdgId(j))
Line 169: Line 169:
 # h1.toTable()  # h1.toTable()
-l1=HLabel("Durham jets  &sigma;=%.3e pb"%cross, 0.3, 0.75, "NDC")+l1=HLabel("Durham jets  &sigma;=%.3e pb"%cross, 0.4, 0.75, "NDC")
 l1.setFont(Font("Helvetica", Font.PLAIN, 14)) l1.setFont(Font("Helvetica", Font.PLAIN, 14))
 c1.add(l1) c1.add(l1)
-l2=HLabel("=HepSim=",0.7,0.87, "NDC"+c1.cd(1,2) # plot rapidity
-l2.setColor(Color.gray) +
-l2.setFont(Font("Helvetica", Font.PLAIN, 14)) +
-c1.add(l2) +
-# plot rapidity +
-c1.cd(1,2)+
 c1.setNameX("Rapidity") c1.setNameX("Rapidity")
 c1.setNameY("Events") c1.setNameY("Events")
Line 215: Line 210:
 {{:fcs:validation_fccee.png?nolink&400|}} {{:fcs:validation_fccee.png?nolink&400|}}
 +=====  Data streaming =====
 +One can also analyze truth-level files using data streaming, i.e. without downloading the actual input files.
 +This example shows data for Higgs to bbar at 240 GeV e+e-.
 +Click the code shown below, save it as "example.py" and run it inside Jas4pp (https://atlaswww.hep.anl.gov/asc/jas4pp/) or using hs-tools package (as "hs-run example.py").
 +<hidden Click here to show the Python/Jython code>
 +<code python>
 +# illustration of how to make pT distribution in real time using data streaming
 +# S.Chekanov (ANL)
 +from java.awt import Color,Font
 +from java.lang import *
 +from proto import FileMC
 +from jhplot import HPlot,H1D,H2D,P1D,HLabel  # graphics
 +from jhplot.utils import FileList
 +from hephysics.particle import LParticle
 +from hephysics.hepsim import PromcUtil
 +from hephysics.jet import JetN2
 +from hepsim import HepSim
 +import sys,math
 +TotalEvents=10000
 +dataset="gev240ee_pythia8_higgs_bbar"
 +tag="" # only truth level
 +url=""
 +NMax=0
 +if len(sys.argv)>1:
 +   flist=FileList.get(sys.argv[1],"promc")
 +   if (len(sys.argv)>2): NMax=int(sys.argv[2])
 +else:
 +   sites=HepSim.urlRedirector(dataset)
 +   url=sites[0]+"/"+tag
 +   flist=HepSim.getList(url)
 +if len(flist)==0: print "Error: No input file!"; sys.exit(0)
 +else: print "Reading "+str(len(flist))+" files. Nr of files= ",NMax
 +#h1.doc()               # check its methods
 +h1= H1D("pT [GeV]",100,0,100)
 +c1 = HPlot("=HepSim=",500,500)
 +c1.visible(True)
 +c1.setAutoRange(True)
 +c1.setMarginLeft(90)
 +c1.setLegend(0)
 +cross=0; nev=0;  Nfiles=len(flist)
 +for m in range(Nfiles):              # loop over all files in this list
 +   file=FileMC(url+flist[m])         # get input file
 +   print "Read=",flist[m]
 +   header = file.getHeader()
 +   un=float(header.getMomentumUnit()) # conversion units
 +   lunit=float(header.getLengthUnit())
 +   if m==0:
 +       print "ProMC v=",file.getVersion(), "M unit=",un,"L unit=",lunit
 +   if (nev>TotalEvents): print "Max Nr of events are done"; break # stop after some events
 +   for i in range(file.size()):
 +      if (nev>TotalEvents): break
 +      nev=nev+1
 +      if (nev%1000==0):
 +           if (Nfiles==1): print "Event=",nev
 +           else:
 +                print "Event=",nev," done=",int((100.0*m)/Nfiles),"%"
 +                c1.clearData()
 +                #c1.setNameX("p_{T}(lead. jet) [GeV]")
 +                #c1.setNameY("Entries")
 +                c1.draw(h1)
 +                print "Update canvas"
 +      eve = file.read(i)
 +      pa = eve.getParticles()    # particle information
 +      nt=0; xsum=0;
 +      darkpi={}
 +      #print " "
 +      for j in range(pa.getPxCount()):
 +         apdg=abs(pa.getPdgId(j))
 +         par=LParticle(pa.getPx(j)/un,pa.getPy(j)/un,pa.getPz(j)/un,pa.getEnergy(j)/un,pa.getMass(j)/un)
 +         nt=nt+1
 +         h1.fill(par.perp()) # calculate transverse mementa
 +   stat = file.getStat()
 +   cross=stat.getCrossSectionAccumulated()
 +   erro=stat.getCrossSectionErrorAccumulated();
 +   file.close()
 +# show final cross section
 +c1.clearData()
 +c1.clear()
 +#c1.setLogScale(1,1)
 +#c1.setRangeY(0,01)
 +c1.setRangeX(0,100)
 +c1.setNameX("p_{T} [GeV]")
 +c1.setNameY("Events")
 +c1.draw(h1)
 +print h1.getStat()
 +#l1=HLabel("&sigma;=%.3e pb"%cross, 0.4, 0.75, "NDC")
 +#l1=HLabel("<m>=%.3e GeV"%h2.mean(), 0.4, 0.75, "NDC")
 +#l1.setFont(Font("Helvetica", Font.PLAIN, 15))
 +#c1.add(l1)
 +l2=HLabel("=HepSim=",0.6,0.85, "NDC")
 +l2.setColor(Color.gray)
 +l2.setFont(Font("Helvetica", Font.PLAIN, 14))
 +c1.add(l2)
 +# create file/image using name of the file
 +name="output"
 +from jhplot.io import HBook
 +file=HBook(name+".jdat","w"); print name+".jdat created"
 +file.write("pT",h1)
 +file.close()
 +c1.export(name+".svg");    print name+".svg created"
 +#xsec.toFile(name+".txt");  print name+".txt created"
 +#sys.exit(0)
 +</code>
 +</hidden>
 +If you run this code as Jython script inside Jas4pp, you will see a histogram updated in real time:
 +{{ :fcs:fccee:screenshot_from_2023-05-24_08-57-19.png?400 |}}
 +=====  Analysis of LCIO files =====
 +Full example of how to analyse LCIO files is given in: https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=asc:jas4pp#reading_lcio_files
 ===== Preparation for fast simulation ===== ===== Preparation for fast simulation =====
Line 300: Line 422:
 </code> </code>
-This script creates the output file in the directory "out"You ca view events in this file as:+This script creates the output file in the directory "out"One can view events in this file as:
 <code bash> <code bash>
Line 328: Line 450:
 The output file will be  data/gev250ee_zh_nunubb_001.root  The output file will be  data/gev250ee_zh_nunubb_001.root
-===== Full simulation =====+
 +===== Full simulation and file conversions =====
 For full simulations, we will need to convert ProMC files to the LCIO files.  You can use the converter posted to https://github.com/hepsim-org/promc2other For full simulations, we will need to convert ProMC files to the LCIO files.  You can use the converter posted to https://github.com/hepsim-org/promc2other
 Read the README of this simple tool. Read the README of this simple tool.
 +The C++ version of the ProMC package can also convert files to HEPMC2 and LHEF.  Look at the directories:
 +<code>
 +cd $PROMC/promc2hepmc   # tool to convert to HEPMC2
 +cd $PROMC/promc2lhe         #  tool to convert to LHEf
 +</code>
 +The key4hep requires HEPMC3 format (not HEPMC2). Therefore, the current option is to convert PROMC to HEMC2 and then convert HEPMC3. Alternatively, key4hep can take LHE files.
 +First, get the script:
 +<code>
 +wget http://fccsw.web.cern.ch/utils/converters/lhe2edm.sh
 +</code>
 +Then use it like this:
 +<code>
 +$ source /cvmfs/sw.hsf.org/key4hep/setup.sh
 +$ ./lhe2edm.sh inputfile.lhe output.edm [--nevt=1000] [--stable]
 +</code>
 +You can specify the number of events in the file in the case the guess based on grepping <event> is wrong.
 +If you specify ‘—stable’ only the stable particles (status == 1) are kept in the final file.
 ===== Some outreach  ===== ===== Some outreach  =====
-If you are a student who has  never seen a typical e+e- event in real life, you may use this simple tool to display and view e+e- events. Here we will explore  typical e+e- events at the CM energy 250 GeV with Higgs  decaying to two Z bosons. Then Z-bosons decay to 4 leptons.  The events will be visualized in the SID detector from the ILC project (events for FCC-ee will not look very different, but the FCC-ee detector will have somewhat different geometry). Unlike the tutorial discussed above, this example requires a personal Linux/Windows/Mac computer with Java installed. It will use the [[https://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]] program and files from HepSim.+If you are a student who has  never seen a typical e+e- event in real life, you may use this simple tool to display and view e+e- events. Here we will explore  typical e+e- events at the CM energy 250 GeV with Higgs  decaying to two Z bosons. Then Z-bosons decay to 4 leptons.  The events will be visualized in the SID detector from the ILC project (events for FCC-ee will not look very different, but the FCC-ee detector will have somewhat different geometry).  The program uses Jas3/Wired display used for the ILC R&D.
 +Unlike the tutorial discussed above, this example only requires a personal Linux/Windows/Mac computer with Java installed. It will use the [[https://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]] program and files from HepSim.
