Differences
Next revision | Previous revision | ||
hepsim:hs-tools [2017/07/17 21:15] hepsim17 created |
hepsim:hs-tools [2020/05/22 02:49] (current) hepsim17 |
Line 1: | Line 1: | ||
- | {{indexmenu_n> | + | {{indexmenu_n> |
- | ====== Using HS-TOOLS ====== | + | ====== Using hs-toolkit |
Line 10: | Line 10: | ||
- | * [[http://jwork.org/dmelt/| DMelt (community version)]] | + | * [[https://datamelt.org/ |
* [[https:// | * [[https:// | ||
- | See [[http:// | + | ====== Installing hs-toolkit ====== |
+ | Install the hs-toolkit using the " | ||
+ | <code bash> | ||
+ | bash # set to bash if needed | ||
+ | wget https:// | ||
+ | source hs-toolkit/ | ||
+ | This creates the directory " | ||
+ | [[https:// | ||
+ | You can view the commands by typing: | ||
+ | hs-help | ||
+ | This package is used for download, view and analyse HepSim files (truth-level only). | ||
+ | To analyse (*.lcio) files with Geant4 simulations, | ||
+ | [[http:// | ||
+ | include more software component to work with LCIO files. | ||
+ | To analyse ROOT files with fast simulations, | ||
+ | <note tip>Note that you can also use the [[hepsim: | ||
+ | hs-tools commands</ | ||
+ | ====== Downloading files with hs-toolkit ====== | ||
+ | This topic was described in [[https:// | ||
+ | ====== Analysing events with hs-toolkit ====== | ||
+ | ====== Java API hs-toolkit ====== | ||
+ | See [[https:// | ||
+ | ====== Validation scripts ====== | ||
+ | hs-toolkit is used to run the scripts located in [[https:// | ||
