Using hs-toolkit
The package “hs-tools” is a light-weight framework to download ProMC files and run validation scripts. You can use Python to use this package. Here are a few software components that are included in this tool:
Installing hs-toolkit
Install the hs-toolkit using the “bash” shell on Linux/Mac:
bash # set to bash if needed wget https://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz; source hs-toolkit/setup.sh
This creates the directory “hs-toolkit” with HepSim commands. Java7/8 and above should be installed. You can view the commands by typing:
hs-help
This package is used for download, view and analyse HepSim files (truth-level only). To analyse (*.lcio) files with Geant4 simulations, use JAS4PP program, which, in addition to hs-toolkit, include more software component to work with LCIO files. To analyse ROOT files with fast simulations, use Delphes/ROOT frameworks.
Downloading files with hs-toolkit
This topic was described in Downloading files
Analysing events with hs-toolkit
This topic was described in Analysing events
Java API hs-toolkit
Validation scripts
hs-toolkit is used to run the scripts located in Validation macros.
— Sergei Chekanov 2015/03/06 08:49
