User Tools
Site Tools
help
Differences
Link to this comparison view
Both sides previous revisionPrevious revision
Next revision
Previous revision
help [2020/09/18 16:32] chekanovhelp [2021/07/08 13:32] (current) chekanov
Line 1: Line 1:
 +{{htmlmetatags>
 +metatag-robots=(index, follow)
 +metatag-keywords=(snowmass,2021,DPF,APS,American Physical Society,HEP, HandWiki)
 +metatag-description=(Wiki for Snowmass21 DPF of APS. HEP community vision. )
 +metatag-og:description=( Snowmass 2021 Process is organized by the Division of Particles and Fields (DPF) of the American Physical Society)
 ====== Collaborative editing  ====== ====== Collaborative editing  ======
-This wiki was designed  for organization and planning of Snowmass21.  It is not designed on a first place for collaborative editing of Snowmass contributions and science articles. The login of this wiki is typically restricted to the Snowmass conveners. +This wiki is designed  for organization and planning of Snowmass21.  It is not designed on a first place for collaborative editing of Snowmass contributions and science articles. The login of this wiki is typically restricted to the// Snowmass conveners//  (frontier conveners, topical conveners. advisory and steering groups, liaisons)
-If you need a resource for collaborative work on Snowmass contributions (i.e. papers, LOI, notes), here are few suggestions:+If you need a resource for collaborative work on Snowmass21 [[:submissions/start | contributions]] (i.e. articles) ,  here are few suggestions:
-  * Google Doc (note it is not LaTeX friendly) +  * [[https://www.google.com/docs/about/ |Google Doc]]  (noteit is not LaTeX friendly)
-  * [[https://www.overleaf.com/ | Overleaf LaTeX Editor]] (commercial) +  * [[https://www.overleaf.com/ | Overleaf Online Editor]] (commercial online LaTeX editor, paid subscription. Use CERN email for free registration
-  * [[https://handwiki.org/ | HandWiki  encyclopedia]]  (uses the Wikipedia syntax but allows  export to the LaTeX format)+  * [[https://handwiki.org/ | HandWiki  encyclopedia]]  (Wikipedia-style syntax with export to the LaTeX format)
-If you would like to use this wiki to write articles, please contact [email protected]  and we will create a dedicated namespace for your work.+In exceptional cases,  if you would like to use this wiki to write articles, please contact [email protected]  and we will create a dedicated namespace for your work.
 ====== Wikicode syntax ====== ====== Wikicode syntax ======
-This wiki uses  [[:help_syntax | DokuWiki syntax]]  for text formatting. +This Snowmass21 wiki uses  [[:help_syntax | DokuWiki syntax]]  for text formatting.  It has also several plugins which make editing simpler. Some of them are described here
 ====== How to create pages====== ====== How to create pages======
Line 52: Line 60:
 ======  Sharing frontier calendars ====== ======  Sharing frontier calendars ======
 =====  Wiki calendar ===== =====  Wiki calendar =====
Line 82: Line 91:
 ====== Sortable table   ====== ====== Sortable table   ======
-For significant number of entries in a table, this wiki allows to add sortable tables using the [[https://www.dokuwiki.org/plugin:datatables |DataTable]] plugin (see its description). It allows to perform search. It also can be used for sorting the columns by clicking the header of this table. See the example:+
 +In addition to the standard tables explained in  [[:help_syntax | DokuWiki syntax help]], for a significant number of entries in a table, this wiki allows to add sortable tables using the [[https://www.dokuwiki.org/plugin:datatables |DataTable]] plugin (see its description). It allows to perform search. It also can be used for sorting the columns by clicking the header of this table. See the example:
 <datatables page-length="50"> <datatables page-length="50">
Line 98: Line 108:
 </datatables> </datatables>
 </code> </code>
  --- //[[[email protected]|Sergei Chekanov]] 2020/02/25 14:22//  --- //[[[email protected]|Sergei Chekanov]] 2020/02/25 14:22//
help.1600464753.txt.gz · Last modified: 2020/09/18 16:32 by chekanov
Donate Powered by PHP Valid HTML5 Valid CSS Driven by DokuWiki
