community:hepsim:dev_opentasks
Open tasks
There is a number of open tasks that are ideal for young scientists to learn about physics, detector designs and Monte Carlo simulations. Here is the list:
- Improve the converter “promc2lcio”. This Java code converts truth-level Monte Carlo events to the LCIO format which is acceptable for the full simulation. This code is included inside the ProMC package. Look at the directory “examples/promc2lcio”. This code works for Pythia6, Herwig6, Madgraph5, but it fails on promc files created from Pythia8. Take any ProMC file from HepSim create by Pythia8 and see the error.
- The FCC-hh detector has about 300 overlaps of the inner tracker (support structures are shifted, overlaps with the beam pipe). The task is to correct compact.xml file and check for overlaps.
- Each detector should be viewed using online event browser using WebGL or other methods. Please look at the CMS detector example in ispy-webgl.
Please contact me (S.Chekanov) if you are interested in these tasks.
community/hepsim/dev_opentasks.1464101473.txt.gz · Last modified: 2016/05/24 14:51 by asc
