To create full simulations, you will need to convert ProMC files to LCIO files. This is described in converting_to_lcio
UNDER CONSTRUCTION
All information required by Pandora algorithm is stored in the file with the extension “.pandora”. This file is created using GeoConvertor, which reads CalorimeterCalibration.properties file. In particular, it reads:
and sampling fractions. Look at the file:
lcsim/detector-framework/src/main/java/org/lcsim/geometry/compact/converter/pandora/Main.java
