There is a number of technical tasks that are ideal for scientists who would like to contribute to open-source particle simulations and outreach. Help from undergraduate and graduate students are especially welcome. HepSim projects can expand your programming skills. You will learn about physics, Monte Carlo generations, detector designs and data analysis. HepSim uses the same software and tools as those used in actual experiments. The only difference is that the software is not proprietorial, which means you do not need to ask the permission to publish your research based on HepSim data.
Of course, you can do a lot of your own research - here you are limited by your own imagination.
Please contact me (S.Chekanov) if you are interested in these tasks.
