User Tools
Site Tools
community:hepsim:pgun
<< back
Creating single particle samples
Single particle samples are created using the ProMC Java package. Here is an example how to make single particle sample using Jython particle_gun.py. Use Jas4pp to run this script:
wget https://atlaswww.hep.anl.gov/asc/wikidoc/lib/exe/fetch.php?media=community:hepsim:particle_gun.py -O particle_gun.py
fpad particle_gun.py # run this script using Jas4pp
You can modify this script to change pT, Eta etc.
An example implemented in Jython is also given in Dmelt example page. You will need to run either DMelt or Jas4pp to create single-particle sample using the Jython script.
Sergei Chekanov 2016/08/02 14:04
community/hepsim/pgun.1478180605.txt.gz · Last modified: 2016/11/03 13:43 by asc
