HepSim ca be used o create ROOT files after fast detector simulation, or one can analyse events after the Delphes fast simulation program on the fly. The latter approach allows to make changes to the detector geometry by the end-users and, at the the same time, perform an analysis. The output ROOT file only includes histograms defined by the user (but you can also add custom ROOT tree). To do this, use the FastHepSim package that includes Delphes-3.2.0 and ProMC 1.5, as well as an example analysis program. You can find a description of the current HCAL studies that use such an approach.
Follow these steps:
wget http://atlaswww.hep.anl.gov/asc/hepsim/soft/FastHepSim.tgz tar -zvxf FastHepSim.tgz cd FastHepSim/libraries/ ./install.sh
This installs “FastHepSim” which includes Delphes, ProMC and hs-tools to work with HepSim. Then setup the environment
cd .. # go to the root directory source setup.sh
Next, go to the analysis example:
cd analysis make
This compiles the analysis program (analysis.cc) that fills jetPT and muonPT histograms. Now we need to bring data from HepSim and put them somewhere. For this example, we will copy data to the “data” directory:
hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5 data 2 3
This copies 3 files in 2 threads and put them to the directory “data”. Now we are ready to run over these 3 files:
./Make_input data # creates inputdata.txt ./analysis delphes_card_FCC_basic_notau.tcl histo.root inputdata.txt
The first command creates a file “inputdata.txt” with input data. Then the program “analysis” reads the configuration file, data and generates “histo.root” with output histograms. This example uses “delphes_card_FCC_basic_notau.tcl” Delphes configuration file describing a basic FCC detector geometry. Note that we have removed tau tagging since we run over slimmed events with missing mothers of particles.
If you want to access other objects (photons, electrons, b-jets), use Delphes definitions of arrays inside the source code “analysis.cc”. You can put external files into the src/ directory where it will be found by Makefile.
If you still want to look at the event structure in the form of ROOT tree, run the usual Delphes command:
../libraries/Delphes/DelphesProMC delphes_card_FCC_basic_notau.tcl output.root data/mg5_Httbar_100tev_001.promc
where output.root will contain all reconstructed objects. In this case, add “TreeWriter” after “ScalarHT”. If the input file contains complete (non-slimmed) record, one can add “tau” reconstruction (“TauTagging” line).
Try also more sophisticated detector-geometry cards:
Note that “TreeWriter” module should be enabled when creating ROOT files, and disabled when using analysis mode.
HepSim maintains analysis scripts that can be used for comparing Monte Carlo simulations with data from Durham HepData database. For example, click the link with AAD 2013 (Search for new phenomena in photon+jet events collected in proton–proton collisions at sqrt(s) = 8 TeV with the ATLAS detector) paper
HepData maintain Jython scripts that use the same syntax as HepSim. You can start from a HepSim validation script, and before the “export” command, append the scripts with data from Durham HepData database. Or you can start from a HepData “SCaVis” script and add parts from HepSim validation script that reads data from HepSim. Note that SCaVis and DMelt are equivalent.
There are several methods to create ProMC files from MC simulations. The most complete description is given here. Here are several examples:
If are working on a description of how to fill ProMC files from Jetphox or MCFM. At this moment, contact us to get help.
We have very limited support for other formats, since they are typically 1) large files (such as HEPMC); 2) cannot be used for streaming over the network; 3) are not suited in a multi-platform environments (i.e. Windows).
For ANL cluster, you do not need to install Delphes. Simply run the reconstruction as:
source /share/sl6/set_asc.sh $DELPHES/DelphesProMC delphes_card_FCC_notau.tcl mg5_ttbar_100tev_001.root mg5_ttbar_100tev_001.promc
The cards are located in $DELPHES/examples.
If you want to run over multiple ProMC files without manual download, use this command:
java -cp hepsim.jar hepsim.Exec DelphesProMC delphes.tcl output.root [URL] [Nfiles]
where [URL] is HepSim location of files and [Nfiles] is the number of files for processing. The output ROOT will be located inside the “hepsim_output” directory. Here is a small example:
java -cp hepsim.jar hepsim.Exec DelphesProMC delphes.tcl output.root http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5 5
which processes 5 files from Higgs to TTbar sample. Skip “5” at the end to process all files.
ProMC files can be converted to LCIO files for full detector simulation. This is an example of such conversions:
wget http://atlaswww.hep.anl.gov/asc/promc/download/current.php -O ProMC.tgz tar -zvxf ProMC.tgz cd examples/promc2lcio source setup.sh javac promc2lcio.java java promc2lcio file.promc file.slcio
Look at other directories in “examples/”. You can convert ProMC files to many other formats (most converters require installation of the ProMC C++ package).
Particle records from the generators based on LO/NLO+parton showers calculations (PYTHIA, HERWIG, MADGRAPH) are often “slimmed” to reduce file sizes. In the case when records are slimmed, the following algorithm is used:
(status=1 && pT>0.3 GeV ) or # keep final states with pT>0.3 GeV (PID=5 || PID=6) or # keep b or top quark (PID>22 && PID<38) or # keep exotics and Higgs (PID>10 && PID<17) or # keep all leptons and neutrinos
where PID is absolute value of particle codes. Leptons ane neutrinos are also affected by the slimming pT cut. Note: for 100 TeV collisions, the pT cut is increased from 0.3 to 0.4 GeV. For NLO calculations with a few partons + PDF weights, the complete event records are stored.
In the case when the slimming is applied, file sizes are reduced by x2 - x3. In some situation, slimming can affect detector simulation. For example, you should turn of tau reconstruction in Delphes when slimming is used.
