fcs:fcchh:zprime
<< back
Boosted particle studies
The results shown on this page use Jas4pp data-analysis package.
Click here to show how to install it
wget http://atlaswww.hep.anl.gov/asc/jas4pp/download/current.php -O jas4pp.tgz
tar -zvxf jas4pp.tgz
cd jas4pp
source ./setup.sh # takes 5 sec for first-time optimization
SiFCC3 detector
You can study this the geometry of the FCChh-v3 detector using sifcch3 link. This geometry corresponds to rfull005 tag SLCIO files.
Download Z'(10 TeV) to XX final state as:
hs-get tev10mumu_pythia6_zprime10tev_qqbar%rfull005  # qqbar
hs-get tev10mumu_pythia6_zprime10tev_ttbar%rfull005  # ttbar
hs-get tev10mumu_pythia6_zprime10tev_ww%rfull005     # W+W-
An example code which creates jet masses of anti-kT jets (R=0.8) is jetmass.py. It fills 3 histograms with jet masses for leading in pT antiKT jets for Z(10 TeV) to W+W- sample (truth, PFO, Clusters). Run it as:
fpad jetmass.py tev10mumu_pythia6_zprime10tev_ww%rfull005
The created image is shown below
Click to display ⇲
Click to hide ⇱
You can write a C++ code which calls the FastJet (with jet substructure variables) using the packages posted to intro.
fcs/fcchh/zprime.1458740854.txt.gz · Last modified: 2016/03/23 13:47 by asc
