hpc:athenaevtdisplay
Athena Event Displays
VP1 (VirtualPoint1)
Setup
On atlas1.hep.anl.gov
export AVERS=$1 export TEST_AREA=$HOME/athenaTestarea/$1 export ATLAS_LOCAL_ROOT_BASE=/cvmfs/atlas.cern.ch/repo/ATLASLocalRootBase source ${ATLAS_LOCAL_ROOT_BASE}/user/atlasLocalSetup.sh asetup 17.2.11.12,AtlasProduction,slc5
I did this last in ~/athenaTestarea/17.2.11.12.2/
HepMC to POOL
Download this job options file.
get_files Example_McAsciiReader_jobOptions.py
Edit Example_McAsciiReader_jobOptions.py
where it specifies an input filename so that it reads from your file (line 51) and change MCEVENTKEY='GEN_EVENT'
(line 38).
hpc/athenaevtdisplay.1406563194.txt.gz · Last modified: 2014/07/28 15:59 by jchilders
