−Table of Contents
Benchmark tests
IO benchmarks using ProMC format
(E.May)
A number of IO tests are being performed on BlueGene/Q using Pythia8 and Pythia6 MC with the output to ProMC data format
A test to see if I can edit this page! - edmay A link to old Ed May webpages of Vesta work.
Some comments on data/plots of running Pythia6 with ProMC & ProBuf on BG/Q Vesta. This uses the Fortran code from the latest 1.1 tar file which simulates 5000 event per core for pp at 4on4 TeV. Except for the normalizing point at 1 core, all runs use 16 cores per node. Jobs were run through 4096 cores. This last point produced 20.5 M ev in 1197 sec (20 mins).
Fig 1
The first plot shows the (inverse) rate as a function
of core. There is a noticiable jog at 1024 cores and above. I ran a second job at
1024 which reproducible result. I have no reasonable explanation for the observed
behavior. I remark that some earlier studies at smaller number of cores showed this
kind of behavior when mixing the number of nodes/cores down without event level i/o
see http://www.hep.anl.gov/may/ALCF/index1.html.
Fig 2
Plot 2 shows the data arranged as a speed-up presentation. Note the use of log scales which minimises the nonlinearity.
Fig 3
A more appropriate measure is shown in Plot 3 which is the effective utilization of the multiple cores. Above 100 cores the fraction begins to drop reaching only 20% for
= 1024 cores. This is really rather poor performance! The plot 5 shows the I/O performance
which shows that the code is not really pushing the I/O capabilities of Vesta.
