hpc:docker
Using Docker
Some initial tests
I installed Docker on my Macbook, it was quite easy following the directions on the <html><a href='https://www.docker.com/' target='_blank'>Docker website</a></html>.
I played around a little and located an SLC docker image. In a fresh terminal:
->boot2docker init ->boot2docker start ->export DOCKER_TLS_VERIFY=1 ->export DOCKER_HOST=tcp://192.168.59.103:2376 ->export DOCKER_CERT_PATH=/Users/childers/.boot2docker/certs/boot2docker-vm ->docker search slc6 NAME DESCRIPTION STARS OFFICIAL AUTOMATED cern/slc6-base Scientific Linux CERN 6 image ready to use... 2 cern/slc6-lite Lightweight CERN Scientific Linux 6 image 1 cmssw/slc6-vanilla 0 lvarin/slc6_vcs Personal slc6 image for VCS 0 asgc/slc65 Image forked from cern/slc6-base 0 lvarin/slc6_64 Base SLC6 image, no modifications from the... 0 acasajus/slc65 0 anaderi/slc6-devtoolset_1.1 0 cmssw/slc6-externals 0 -> docker pull cern/slc6-base Pulling repository cern/slc6-base 3d85e4d2d936: Download complete beca1e02f1eb: Download complete 79924a46c804: Download complete Status: Downloaded newer image for cern/slc6-base:latest -> docker images REPOSITORY TAG IMAGE ID CREATED VIRTUAL SIZE cern/slc6-base 6.6 3d85e4d2d936 12 weeks ago 911.1 MB cern/slc6-base latest 3d85e4d2d936 12 weeks ago 911.1 MB -> docker run cern/slc6-base:6.5 uname -a Linux f4eea7db246b 3.16.7-tinycore64 #1 SMP Tue Dec 16 23:03:39 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
hpc/docker.1422635827.txt.gz · Last modified: 2015/01/30 16:37 by jchilders
