hpc:docker
Using Docker
Some initial tests
I installed Docker on my Macbook, it was quite easy following the directions on the <html><a href='https://www.docker.com/' target='_blank'>Docker website</a></html>.
I played around a little and located an SLC docker image. In a fresh terminal:
->boot2docker init ->boot2docker start ->export DOCKER_TLS_VERIFY=1 ->export DOCKER_HOST=tcp://192.168.59.103:2376 ->export DOCKER_CERT_PATH=/Users/childers/.boot2docker/certs/boot2docker-vm ->docker search slc6 NAME DESCRIPTION STARS OFFICIAL AUTOMATED cern/slc6-base Scientific Linux CERN 6 image ready to use... 2 cern/slc6-lite Lightweight CERN Scientific Linux 6 image 1 cmssw/slc6-vanilla 0 lvarin/slc6_vcs Personal slc6 image for VCS 0 asgc/slc65 Image forked from cern/slc6-base 0 lvarin/slc6_64 Base SLC6 image, no modifications from the... 0 acasajus/slc65 0 anaderi/slc6-devtoolset_1.1 0 cmssw/slc6-externals 0 -> docker pull cern/slc6-base Pulling repository cern/slc6-base 3d85e4d2d936: Download complete beca1e02f1eb: Download complete 79924a46c804: Download complete Status: Downloaded newer image for cern/slc6-base:latest -> docker images REPOSITORY TAG IMAGE ID CREATED VIRTUAL SIZE cern/slc6-base 6.6 3d85e4d2d936 12 weeks ago 911.1 MB cern/slc6-base latest 3d85e4d2d936 12 weeks ago 911.1 MB -> docker run cern/slc6-base:6.5 uname -a Linux f4eea7db246b 3.16.7-tinycore64 #1 SMP Tue Dec 16 23:03:39 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
As a test I installed ROOT via yum into the image. The first command here starts an interactive container.
-> docker run -i -t cern/slc6-base:6.5 [root@19035251353f /]# yum install root.x86_64 . . < yum installation STDOUT goes here > . [root@19035251353f /]# root -b ******************************************* * * * W E L C O M E to R O O T * * * * Version 5.34/20 12 August 2014 * * * * You are welcome to visit our Web site * * http://root.cern.ch * * * ******************************************* ROOT 5.34/20 (heads/v5-34-00-patches@v5-34-19-251-gfb37e88, Aug 29 2014, 05:50:00 on linuxx8664gcc) CINT/ROOT C/C++ Interpreter version 5.18.00, July 2, 2010 Type ? for help. Commands must be C++ statements. Enclose multiple statements between { }. root [0] .q [root@19035251353f /]# exit -> docker ps -l CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 19035251353f cern/slc6-base:6.5 "bash" 29 minutes ago Exited (0) 3 seconds ago ecstatic_brattain -> docker commit -m "SLC6.5 with ROOT 5.34/20 installed" -a "Taylor Childers" 19035251353f jtchilders/slc65:root534 e0ebe08a3fce057499fcefdf6132c7e57aca605a1830f0abc84f97e431094cb2
Now I have my own SLC6.5 container with ROOT 5.34 installed.
Next I played with trying to run a root script so I made one:
mkdir vlocal vim vlocal/root_test.C
- | root_test.C
#include <string> #include <iostream> int root_test(void){ string test = "Hello World"; std::cout << test << "\n"; return 0; }
Then I wanted my container to mount my local directory and use this file:
-> docker run --volume=$PWD/vlocal:/vcont jtchilders/slc65:root534 root -b -q /vcont/root_test.C ******************************************* * * * W E L C O M E to R O O T * * * * Version 5.34/20 12 August 2014 * * * * You are welcome to visit our Web site * * http://root.cern.ch * * * ******************************************* ROOT 5.34/20 (heads/v5-34-00-patches@v5-34-19-251-gfb37e88, Aug 29 2014, 05:50:00 on linuxx8664gcc) CINT/ROOT C/C++ Interpreter version 5.18.00, July 2, 2010 Type ? for help. Commands must be C++ statements. Enclose multiple statements between { }. Processing /vcont/root_test.C... Hello World (int)0
hpc/docker.1422636444.txt.gz · Last modified: 2015/01/30 16:47 by jchilders
