hpc:pythia
Table of Contents
Building Pythia on BlueGene/Q
Part 1: Build HepMC Library
- Check out HepMC from SVN:
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/tools/HepMC-2.06.08 <destination_path>
- Inside the HepMC folder run
./bgq-make.sh
Part 2: Build Pythia Library
- Check out Pythia from SVN:
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/generators/pythia/v8180/bgq/trunk <destination_path>
- Inside the Pythia folder run
./bgq-make.sh
Part 3: Build Pythia Executable
- Check out TCLAP from SVN:
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/tools/tclap-1.2.1 <destination_path>
- Check out Pythia user code from SVN:
svn co svn+ssh://username@atlas1.hep.anl.gov/users/svn/hpc/generators/pythia/usercode <destination_path>
- Inside the
usercodefolder you will find different programs written to use Pythia. As of this writting there was only one:alpToHepmc/runPythiaOnAlpgen.cppwhich can be used to shower Alpgen events and output HepMC format- There is a
Makefilewhich can be used to make an executable, be sure to edit the paths inside theMakefileto point to the HepMC/Pythia/TCLAP installations
Pythia Performance
On ''acinode.hep.anl.gov''
This is the Pythia performance on ascinode.hep.anl.gov while hadronizing Alpgen Z+N-jet events.
- 'N Showered Events' are the number of events Pythia showered during the test.
- 'CPU Time' are the seconds reported by the 'time' command line that it took Pythia to run.
- 'Rate' = 'N Showered Events'/'CPU Time'
- 'Accepted Events' are the number of events that passed the Jet Matching that Pythia performs in order to avoid double counting.
- 'Acceptance Efficieny' = 'Accepted Events'/'N Showered Events'
- 'Accepted Rate' = 'Accepted Events'/'CPU Time'
If you don't see anything but white-space below this text, hit Ctrl-R (or Cmd-R on a mac).
<html><iframe width='900' height='1100' frameborder='0' src='https://docs.google.com/spreadsheet/pub?key=0Aog5UiCGVmvRdDY5bGc0WTQxVXd5OUJMNVpTZ0JFRWc&single=true&gid=0&output=html&widget=true'></iframe></html>
hpc/pythia.txt · Last modified: 2014/01/21 22:24 by jchilders
