hpc:svnrepo
ATLAS HEP HPC SVN Repository
Repository Coordinates
The repository address is:
svn+ssh://atlas1.hep.anl.gov/users/svn/hpc/
Checkout Repository
Run the following on your command line:
svn co svn+ssh://<username>@atlas1.hep.anl.gov/usrs/svn/hpc <optional local directory name>
This will check out everything in the repository to the directory hpc or if the 'optional local directory name' is given, it will be located in that directory.
hpc/svnrepo.1389286697.txt.gz · Last modified: 2014/01/09 16:58 by jchilders
