itk:module_assembly_procedure
Module Assembly Procedure
The following document describes the method for assembling dummy modules using the tape-assembly method. For the automatic glue dispension method, all steps are the same, except that the epoxy-application steps are replaced with glue-application.
itk/module_assembly_procedure.1472844258.txt.gz · Last modified: 2016/09/02 19:24 by mazhang
