Here is a library with PMT signals with active dividers. The data are collected using R5900 PMT with active dividers and 676 V. Patrick's LED 4 ns width and David's setup
Used 1 neutral density filter 50% (NDF50), and 1 neutral density filter x16 (NDF16)
Download data from https://atlaswww.hep.anl.gov/asc/phase2/data/
