User Tools
Site Tools
snowmass2013:howto_d3
<<back
How to generate events with pileups
This is a tutorial explaining how to generate HERWIG++ signal plus pile up events. You need a Linux computer (this was tested on SL5.9) with installed ROOT. Also, certain libraries require “boost” library:
yum install boost-devel
Then get this tar file which includes HERWIG++, ThePEG, Delphes 3.08, Pythia8, HEPMC. package.tgz
export PATH=.:$PATH
wget http://mc.hep.anl.gov/asc/snowmass2013/delphes36/packages/package.tgz
tar -zvxf package.tgz
cd package_snowmass13
build.sh # if this is SL5.9, do not need to run this script!
The build script attempts to detect your environments and the installs HERWIG++, ThePEG, Delphes 3.08, HEPMC (not in the same order) If some luck, installation can be successful.
To generate pileup (example):
cd  herwigpp/run_pileup_ttbar_highPT
A_RUN_pileup.sh*
To generate signal:
A_RUN_signal.sh
Please examine it. If you need to change the signal events, look at the HERWIG++ “LHC_signal.in” card, where you can set needed process.
Sergei Chekanov 2013/03/19 21:06A.Vaniashine 2013/03/19 21:06
snowmass2013/howto_d3.txt · Last modified: 2014/04/24 01:51 by 127.0.0.1
