snowmass2013:montecarlo_d36ponyisi
A collections of Higgs+ttbar samples
Here are samples of Delphes 3.09 events generated for the 14 TeV center-of-mass energy (pp collisions). HEPMC files are generated by Peter Onyisi ([email protected]). The events are generated for 0, 50 and 140 pileup scenarios. Data are stored in the ROOT format using the standard Delphes output. The samples use the “Snowmass” detector geometry. Jets were corrected using jet area correction and fake jets are not stored. See this wiki for details.
The MadGraph samples are located here. ROOT files contain reconstructed Delphes outputs, ProMC files contain original HEPMC truth record.
Here is the info from Peter:
user.ponyisi.test.ttww.pythia.v1/ - ttWW + up to 1 parton user.ponyisi.test.tth_tautau.pythia.v1/ - ttH, H -> tau tau, generic tau decay + up to 1 parton user.ponyisi.test.ttll.pythia.v1/ - tt + ll + up to 2 partons, dilepton invariant mass >= 10 GeV user.ponyisi.test.tth_zz.pythia.v1/ - ttH, H -> ZZ, generic Z decay + up to 1 parton user.ponyisi.test.ttw.pythia.v1/ - ttW + up to 3 partons, generic W decay user.ponyisi.test.tth.pythia.v1/ - ttH, H->WW + up to 1 parton, generic W decay
snowmass2013/montecarlo_d36ponyisi.txt · Last modified: 2014/04/24 01:51 by 127.0.0.1
