User Tools
Site Tools
snowmass2013:montecarlo_d36pt1800
<<back
High-pT ttbar (pT>1500 GeV)
Here are samples of Delphes 3.08 events generated for the 14 TeV center-of-mass energy (pp collisions). The events are generated for 0, 50 and 140 pileup scenarios. All data are stored in the ROOT format using the standard Delphes output. Therefore, it is recommended to install Delphes and look at the example explaining how to read such ROOT files (see the directory “Examples” inside the Delphes package). The samples use the “Snowmass” detector geometry. Jets were corrected using jet area correction and fake jets are not stored. See this wiki for details.
How to download
Please read the Section How to download. You need a python script “download.py”.
Signal ttbar
This is a ttbar fully inclusive top sample (all top decays) with pT>1500 GeV on hard processes using HERWIG++ with sqrt(s)=14 TeV. The LO ME processes are:
g g -> t tbar
q qbar -> t tbar
Look at the HERWIG++ log file used to generate such files.This is input settings
In total, there are 96 files per sample (mu=0,50,140), with 1000 ttbar events in each. Thus the total number of events is 96000 signal events per sample.
No pileup
Get the Delphes3 ROOT files from this download link. Here is an example for downloading 5 files:
python download.py 5  delphes36/ttbar_pt1800/mu0  herwigpp_ttbar_pt1800_delphes306
(set 5 to 96 to download all)
<mu>=50
python download.py 5  delphes36/ttbar_pt1800/mu50  herwigpp_ttbar_pt1800_delphes306_mu50
<mu>=140
python download.py 5  delphes36/ttbar_pt1800/mu140  herwigpp_ttbar_pt1800_delphes306_mu140
How to analyze using ROOT
If you need to find the effect of pileup on top reconstruction or a jet measurement, you need to run the analysis code over signal MC and then over the signal+pileup MC files. Read analyse_d3
How to analyze without ROOT
In some cases, you may not have ROOT installed to read the Delphes files. In this case, you can use ROOT files converted to the ProMC format which can be read without ROOT (using C++, Java, Python). Read how to read Delphes3 output without ROOT.
Sergei Chekanov 2013/03/06 20:48
snowmass2013/montecarlo_d36pt1800.txt · Last modified: 2014/04/24 01:51 by 127.0.0.1
