−Table of Contents
TileCal maintenance
The division is traditionally involved in TileCal Maintenance. Here are a few photos of the 2018 maintenance complain:
http://atlaswww.hep.anl.gov/asc/tilecal/maintenance2018/
Description: MobiDick4 wiki Mobidick note Mobidick note4
Setting up MobiDick computers
http://ftp1.scientificlinux.org/linux/scientific/7x/x86_64/iso/
https://twiki.cern.ch/twiki/bin/view/Atlas/MobiDick4#Laptop
Software link: https://svnweb.cern.ch/trac/atlasgroups/browser/Detectors/TileCal/MobiDICK
Computer1: mobi1 (user/pass)
HP ProBook 450 G5. CSI 0356567
Install from USB CDROM: F10, the go to boot, then go to “install from file”.
Mobidick server parameters:
192.168.0.102 1570 (port) xterm -hold -e "expect -c 'spawn telnet -l root 192.168.0.102; expect \"Password:\"; send \"root\r\"; send \"./soft/MobiDICK\r\"; interact'"
Should install: xterm, telnet, expect
The IP 192.168.0.100 should be assigned to laptop automatically via DHCP server
Differences between software new vs old (working) version
DigNoise panel is different.
Willy version 2.9 2013-02-20 Mobidick version 5.7 David Calvet
Working version has “Pedestal noise result” with 52 buttons. New version has two bars, “High Gain test results” and “Low gain test results” with 52. Then, below: “Pedestal spread results”.
