User Tools
Site Tools
tilecal:maintenance
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
tilecal:maintenance [2018/11/16 12:11]
asc
tilecal:maintenance [2018/11/16 12:16]
asc
Line 52: Line 52:
 Working  version has "Pedestal noise result"  with 52  buttons. Working  version has "Pedestal noise result"  with 52  buttons.
 New version  has two bars, "High Gain test results" and "Low gain test results" with 52. Then, below: "Pedestal spread results". New version  has two bars, "High Gain test results" and "Low gain test results" with 52. Then, below: "Pedestal spread results".
 +===== DigLinerarity =====
 +This panel is missing in the working version
 +===== DigNoiseHV =====
 +Working version has only 52 buttons with "Pedestal noise results"
 +New version has High Gain test results, "Low Gain results" and "Pedestal spread test result"
tilecal/maintenance.txt · Last modified: 2021/01/14 21:24 by asc
