asc:asc_afs
How to install AFS
Instruction from Bob:
Here is how to setup afs:
Install the following packages (these are from the standard sl6 repo):
kmod-openafs
openafs
openafs-module-tools
openafs-krb5
openafs-client
You should make sure afs starts at boot and the only customization
required is, after installing the above and before starting the afs
service, do "echo cern.ch >/usr/vice/etc/ThisCell" as root.
To gain access to non-public files at cern you need to 1) get a kerberos
ticket with kinit and 2) issue the aklog command to translate it to an
afs token.
asc/asc_afs.1382365544.txt.gz · Last modified: 2013/10/21 14:25 by asc
