Open tasks
There is a number of technical tasks that are ideal for scientists who would like to contribute to open-source particle simulations and outreach. Help from undergraduate and graduate students are especially welcome. HepSim projects can expand your programming skills, you will learn about HEP physics processes, Monte Carlo generators, detector designs and data analysis. HepSim uses the same general software and tools as for the ongoing and future experiments. The only difference is that HepSim packages are not proprietorial, which means you do not need to ask permissions from HEP experiments/collaborations to publish your own research based on HepSim simulations.
Here are several open tasks:
- Improve the converter “promc2lcio”. This Java code converts truth-level Monte Carlo events to the LCIO format for the full simulation. The promc2lcio code is included inside the ProMC package. Look at the directory “examples/promc2lcio”. This code works for Pythia6, Herwig6, Madgraph5, but it fails on promc files created from Pythia8. Take any ProMC file from HepSim create by Pythia8 and see the error.
- The FCC-hh detector has about 300 overlaps of the inner tracker (support structures are shifted, overlaps with the beam pipe). The task is to correct compact.xml file into GDML file, and check for overlaps using the existing tools included into ROOT.
- Each detector should be viewed using online event browser based on WebGL or other methods. Please look at the CMS detector example in ispy-webgl.
- Improvements for the graphics of Jas4pp used to visualize the events. Currently, HCAL cell sizes are shown as small dots which do not reflect the actual size of calorimeter cells.
- Improvements in HepRApp code. Currently, it is not actively supported (and the source code is not available). But the tool gives a sample method to view events
Of course, you can do a lot of your own research, including physics performance studies using truth-level, fast simulations and full simulations. You are limited only to your own imagination.
Please contact me (S.Chekanov) if you are interested in these tasks.
— Sergei Chekanov 2016/05/24 10:14
