hpc:magellan
Torque
Install
On CERN VMWare 3.0 image
http://wiki.hpc.ufl.edu/doc/TorqueHowto
For server:
rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/epel-release-6-8.noarch.rpm
rpm -Uvh http://rpms.famillecollet.com/enterprise/remi-release-6.rpm
rpm -Uvh http://dl.atrpms.net/all/atrpms-repo-6-7.el6.x86_64.rpm
yum install torque-client torque-server torque-scheduler
echo "$NODE_HOSTNAME np=8" >> /var/lib/torque/server_priv/nodes
/etc/torque/server_name: echo $(hostname --short) > /etc/torque/server_name;
pbs_server -t create
For client:
yum install torque-client torque-mom
Another Try:
Server:
wget link comes from http://www.adaptivecomputing.com/download/torque/torque-5.1.0-1_4048f77c.tar.gz http://docs.adaptivecomputing.com/suite/8-0/basic/help.htm#topics/torque/1-installConfig/installing.htm https://github.com/spuder/torque-setup/issues/1 http://linuxtoolkit.blogspot.com/2014/06/resolution-for-error-cannot-set-torque.html
wget http://www.adaptivecomputing.com/index.php?wpfb_dl=2868
mv index.php?wpfb_dl=2868 torque-5.1.0-1_4048f77c.tar.gz
tar zxf torque-5.1.0-1_4048f77c.tar.gz
cd torque-5.1.0-1_4048f77c
./configure
make
make install
cp contrib/init.d/trqauthd /etc/init.d/
chkconfig --add trqauthd
echo /usr/local/lib > /etc/ld.so.conf.d/torque.conf
ldconfig
service trqauthd start
make packages # for copying to nodes
echo "<ip-address> torque-server-01.novalocal torque-server-01" >> /etc/hosts
./torque.setup root
hpc/magellan.txt · Last modified: 2015/03/30 17:47 by jchilders
