snowmass2013:montecarlo_d36loginov
A collections of ttbar samples
Here are samples of Delphes 3.08 events generated for the 14 TeV center-of-mass energy (pp collisions). HEPMC files are generated by Andrey Loginov ([email protected]). The events are generated for 0, 50 and 140 pileup scenarios. Data are stored in the ROOT format using the standard Delphes output. The samples use the “Snowmass” detector geometry. Jets were corrected using jet area correction and fake jets are not stored. See this wiki for details.
The MadGraph samples are located here
Here is the info from Andrey:
Note that for all the samples photons we have a full ME photon radiation treatment. For instance, for tta (ljets) the generation was performed using: generate p p > t t~ > l+ vl b j j b~ a @1 add process p p > t t~ > l- vl~ b~ j j b a @2 == ttaa (dilepton) ttaa_tt_dilepton_run_07_unweighted_events.lhe (and the split .event and .tar.gz files) nevents = 20000 xsec = 0.47187E-02 pb == ttaa (ljets) ttaa_tt_ljets_run_05_unweighted_events.lhe (and the split .event and .tar.gz files) nevents = 20000 xsec = xsec = 0.11894E-01 pb == tta (dilepton) tta_tt_dilepton_run_03_unweighted_events.lhe (and the split .event and .tar.gz files) nevents = 50000 xsec = 0.67816E+00 pb == tta (ljets) tta_tt_ljets_run_07_unweighted_events.lhe (and the split .event and .tar.gz files) nevents = 100000 xsec = 0.15678E+01 pb == waa+0/1/2 jets (incl HF) waa0jj_hf_run_01_unweighted_events.lhe (and the split .event and .tar.gz files) nevents = 100000 xsec = 0.51095E+00 pb == zaa+0/1/2 jets (incl HF) zaa0jj_hf_run_01_unweighted_events.lhe (and the split .event and .tar.gz files) nevents = 100000 xsec = 0.25014E+00 pb
snowmass2013/montecarlo_d36loginov.txt · Last modified: 2014/04/24 01:51 by 127.0.0.1
