Here are the links to the existing Monte Carlo samples for top-quark studies generated for the 14 TeV center-of-mass energy (pp collisions). Events were generated with the PYTHIA8 and HERWIG++ models, and processed using the Delphes 2.03 fast detector simulation.
All data are stored as ROOT files using the standard Delphes 2.0.3 output. Therefore, it is recommended to install Delphes 2.0.3 and look at the example explaining how to read such ROOT files (see the directory “Examples” inside the Delphes package).
Information about the geometry (resolutions) is given in these Delphes input files (comes with the default Delphes installation):
The output ROOT files have the truth information and the detector-level objects (jets, leptons etc).
Please read How to download the link the link
First you need to install ROOT. Then the procedure is somewhat different depending on what Delphes version you are using, “Delphes 2.03” (production) or Delphes 3.0 (beta). Go to the Delphes web page and download the needed version. The packages contain basic examples of how to read ROOT files generated by Delphes. One example for Delphes 3.0(beta) is given in this section
Let's do some analysis using the files given on this web page. Download Delphes_V_2.0.3.tar.gz and compile it (should work on Scientific Linux 5 or 6):
wget --no-check-certificate https://cp3.irmp.ucl.ac.be/projects/delphes/raw-attachment/wiki/WikiStart/Delphes_V_2.0.3.tar.gz tar -zvxf Delphes_V_2.0.3.tar.gz cd Delphes_V_2.0.3/ make
You will see this:
Click to display ⇲
Click to hide ⇱
>> Generating tmp/Utilities/ExRootAnalysis/src/BlockClassesDict.cc >> Compiling tmp/Utilities/ExRootAnalysis/src/BlockClassesDict.cc >> Generating tmp/src/TreeClassesDict.cc >> Compiling tmp/src/TreeClassesDict.cc ........................................ many messages >> Building Frog_on_analysis_output >> Compiling Examples/Convertors_Only.cpp >> Building Convertors_Only Delphes has been compiled Ready to run
The directory “Examples” contains the example source code. Let's replace it with our example program. snowmass_tutorial.tgz
mv Delphes_V_2.0.3/Examples Delphes_V_2.0.3/Examples_old cd /tmp wget --no-check-certificate https://mc.hep.anl.gov/asc/wikidoc/lib/exe/fetch.php?media=snowmass2013:snowmass_tutorial.tgz tar -zvxf snowmass_tutorial.tgz mv /tmp/snowmass_tutorial/* Delphes_V_2.0.3/ # copy the content to the Delphes installation cd Delphes_V_2.0.3/ make # recompile again
The new code which is inside “Examples” calculated some basic histograms for the top production. You can run it using the script “A_RUN”. Open it and define the path to the directory with ROOT files. The run it as “./A_RUN”. The program runs over the list of ROOT files and creates a ROOT file with histograms inside “out/” directory.
The generator-level settings are given below. No pile-up was included.
The events were generated with this input card: analysis.ini. The luminosity info and cross section for 5000 generated events can be found here:
Click to display ⇲
Click to hide ⇱
*------- PYTHIA Event and Cross Section Statistics -------------------------------------------------------------* | | | Subprocess Code | Number of events | sigma +- delta | | | Tried Selected Accepted | (estimated) (mb) | | | | | |-----------------------------------------------------------------------------------------------------------------| | | | | | g g -> t tbar 601 | 43612 2785 2785 | 2.039e-10 1.833e-12 | | q qbar -> t tbar 602 | 21140 2215 2215 | 1.616e-10 1.798e-12 | | | | | | sum | 64752 5000 5000 | 3.655e-10 2.568e-12 | | | *------- End PYTHIA Event and Cross Section Statistics ----------------------------------------------------------* *------- PYTHIA Error and Warning Messages Statistics ----------------------------------------------------------* | | | times message | | | | 22 Error in Pythia::next: hadronLevel failed; try again | | 22 Error in StringFragmentation::fragment: stuck in joining | | 1 Warning in MultipartonInteractions::pTnext: weight above unity | | 17 Warning in SpaceShower::pT2nextQCD: weight above unity | | 17 Warning in StringFragmentation::fragmentToJunction: bad convergence junction rest frame | | | *------- End PYTHIA Error and Warning Messages Statistics ------------------------------------------------------* == Cross section for this run=3.655e-01 pb == Events for this run=5000 == Luminosity for this run=1.368e+01 fb-1 == Number of top-quark events =813 sigma (fb)=5.942e+01 == Number of W events =206 sigma (fb)=1.506e+01 == Number of Z events =0 sigma (fb)=0.000e+00
Get the ROOT files from the download link
Example for downloading 5 files:
python download.py 5 pythia8/ttbar650pt pythia8_ttbar_pt650
I total there are 80 files to download. This gives 80×5000=400,000 events.
The log file for 5000 generated events is here:
Click to display ⇲
Click to hide ⇱
============================================================================== Total: 155528 155528 2.31111e+08 ============================================================================== Per matrix element breakdown: MEQCD2to2Fast 155528 155528 2.31111e+08 ============================================================================== ============================================================================== Eikonalized and soft cross sections: Model parameters: ptmin: 3.5973 GeV, mu2: 0.81 GeV2 DL mode: 2, CMenergy: 14000 GeV hard inclusive cross section (mb): 230.943 soft inclusive cross section (mb): 27.5083 total cross section (mb): 113.95 inelastic cross section (mb): 78.5474 soft inv radius (GeV2): 0.306276 slope of soft pt spectrum (1/GeV2): -0.840612 Average hard multiplicity: 5.46146 Average soft multiplicity: 0.36554 ============================================================================== >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>> ThePEG - Toolkit for HEP Event Generation - version 1.8.1 <<<<<<<<<< <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ============================================================================== Statistics for event handler 'LHCHandler': generated number of Cross-section events attempts (nb) ============================================================================== Total (from weighted events): including vetoed events 1.246(9)e-03 ============================================================================== Total (from unweighted events): 5000 5028 1.24(2)e-03 ============================================================================== Per matrix element breakdown: MEHeavyQuark 5000 5028 1.24(2)e-03 ==============================================================================
python download.py 5 herwigpp/ttbar650pt herwigpp_ttbar_pt650
In total, there are 80 files to download. This gives 80×5000=400,000 events.
The total luminosity for inclusive QCD jet sample is roughly 9.6 fb-1 (for each sample, PYTHIA and HERWIG). The files are grouped in 2 directories and one should combine them to get ~9.6 fb-1.
Click to display ⇲
Click to hide ⇱
*------- PYTHIA Event and Cross Section Statistics -------------------------------------------------------------* | | | Subprocess Code | Number of events | sigma +- delta | | | Tried Selected Accepted | (estimated) (mb) | | | | | |-----------------------------------------------------------------------------------------------------------------| | | | | | g g -> g g 111 | 5470 831 831 | 2.753e-08 4.985e-10 | | g g -> q qbar (uds) 112 | 130 24 24 | 7.833e-10 8.864e-11 | | q g -> q g 113 | 20816 2679 2679 | 9.207e-08 8.796e-10 | | q q(bar)' -> q q(bar)' 114 | 9979 1323 1323 | 4.509e-08 6.070e-10 | | q qbar -> g g 115 | 97 17 17 | 6.241e-10 7.790e-11 | | q qbar -> q' qbar' (uds) 116 | 70 19 19 | 5.035e-10 6.732e-11 | | g g -> c cbar 121 | 52 4 4 | 1.507e-10 3.342e-11 | | q qbar -> c cbar 122 | 23 7 7 | 1.925e-10 4.638e-11 | | g g -> b bbar 123 | 33 6 6 | 2.810e-10 6.515e-11 | | q qbar -> b bbar 124 | 22 8 8 | 2.282e-10 5.441e-11 | | q g -> q gamma (udscb) 201 | 17 2 2 | 1.968e-10 5.069e-11 | | q qbar -> g gamma 202 | 8 4 4 | 6.074e-11 2.082e-11 | | g g -> g gamma 203 | 0 0 0 | 0.000e+00 0.000e+00 | | f fbar -> gamma gamma 204 | 0 0 0 | 0.000e+00 0.000e+00 | | g g -> gamma gamma 205 | 0 0 0 | 0.000e+00 0.000e+00 | | f fbar -> gamma*/Z0 221 | 59 11 11 | 4.135e-10 7.896e-11 | | f fbar' -> W+- 222 | 107 31 31 | 8.721e-10 9.339e-11 | | f fbar -> gamma*/Z0 gamma*/Z0 231 | 4 1 1 | 6.196e-12 6.196e-12 | | f fbar' -> Z0 W+- (no gamma*!) 232 | 2 0 0 | 0.000e+00 0.000e+00 | | f fbar -> W+ W- 233 | 4 0 0 | 0.000e+00 0.000e+00 | | q qbar -> gamma*/Z0 g 241 | 19 2 2 | 6.789e-11 3.454e-11 | | q g-> gamma*/Z0 q 242 | 101 11 11 | 2.479e-10 5.253e-11 | | f fbar -> gamma*/Z0 gamma 243 | 0 0 0 | 0.000e+00 0.000e+00 | | q qbar' -> W+- g 251 | 35 3 3 | 1.787e-10 3.979e-11 | | q g-> W+- q' 252 | 118 17 17 | 5.763e-10 6.943e-11 | | f fbar' -> W+- gamma 253 | 2 0 0 | 0.000e+00 0.000e+00 | | | | | | sum | 37168 5000 5000 | 1.701e-07 1.203e-09 | | | *------- End PYTHIA Event and Cross Section Statistics ----------------------------------------------------------* == Cross section for this run=1.701e+02 pb == Events for this run=5000 == Luminosity for this run=2.940e-02 fb-1 == Number of top-quark events =0 sigma (fb)=0.000e+00 == Number of W events =2 sigma (fb)=6.803e+01 == Number of Z events =3 sigma (fb)=1.020e+02
Get the ROOT files grouped in 2 directories:
python download.py 5 pythia8/qcd650pt/run1 pythia8_qcd_pt650 python download.py 5 pythia8/qcd650pt/run2 pythia8_qcd_pt650_2
The MC samples were generated for inclusive jets events. The part of the log file with the cross sections is shown below (for 5000 events):
Click to display ⇲
Click to hide ⇱
Miscellaneous output from modules to the standard output: Statistics for the UE process: generated number of Cross-section events attempts (nb) ============================================================================== Total: 153340 153340 2.30923e+08 ============================================================================== Per matrix element breakdown: MEQCD2to2Fast 153340 153340 2.30923e+08 ============================================================================== ============================================================================== Eikonalized and soft cross sections: Model parameters: ptmin: 3.5973 GeV, mu2: 0.81 GeV2 DL mode: 2, CMenergy: 14000 GeV hard inclusive cross section (mb): 231.373 soft inclusive cross section (mb): 27.2365 total cross section (mb): 113.95 inelastic cross section (mb): 78.5401 soft inv radius (GeV2): 0.304806 slope of soft pt spectrum (1/GeV2): -0.884655 Average hard multiplicity: 5.47163 Average soft multiplicity: 0.360742 ============================================================================== >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>> ThePEG - Toolkit for HEP Event Generation - version 1.8.1 <<<<<<<<<< <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ============================================================================== Statistics for event handler 'LHCHandler': generated number of Cross-section events attempts (nb) ============================================================================== Total (from weighted events): including vetoed events 0.168(1)e+00 ============================================================================== Total (from unweighted events): 5000 5038 0.167(3)e+00 ============================================================================== Per matrix element breakdown: MEQCD2to2 4989 5027 0.166(3)e+00 MEGammaJet 4 4 0.13(7)e-03 MEZJet 1 1 30(30)e-06 MEWJet 6 6 0.20(8)e-03 ==============================================================================
Get the ROOT files from these 2 locations:
python download.py 5 herwigpp/qcd650pt/run1 herwigpp_qcd_pt650 python download.py 5 herwigpp/qcd650pt/run2 herwigpp_qcd_pt650_2
— Sergei Chekanov 2013/01/31 08:52
