fcs:fcchh:zprime
Boosted particle studies
The results shown on this page use Jas4pp data-analysis package.
SiFCC3 detector
You can study this the geometry of the FCChh-v3 detector using sifcch3 link. This geometry corresponds to rfull005 tag SLCIO files.
Download Z'(10 TeV) to XX final state as:
hs-get tev10mumu_pythia6_zprime10tev_qqbar%rfull005 # qqbar hs-get tev10mumu_pythia6_zprime10tev_ttbar%rfull005 # ttbar hs-get tev10mumu_pythia6_zprime10tev_ww%rfull005 # W+W-
An example code which creates jet masses of anti-kT jets (R=0.8) is attached. jetmass.py. It fills 3 histograms with jet masses for leading antiKT jets and Z(10 TeV) to W+W- (truth, PFO, Clusters). Run it as
fpad jetmass.py tev10mumu_pythia6_zprime10tev_ww%rfull005
The created image is shown below
You can write a C++ code which calls C++ fastjets using the code example posted to intro.
fcs/fcchh/zprime.1458740573.txt.gz · Last modified: 2016/03/23 13:42 by asc
