Module | Trip time | Symptom, problem found | DCS image |
EBC62 | 2015-04-22 11:18:28 | NOT a real trip, EBC62 was power-cycled requested by DCS to fix timing jump (power-cycled https://atlasop.cern.ch/elisa/display/258617 ; timing jump https://atlasop.cern.ch/elisa/display/258618) | |
LBC31 | 2015-04-03 10:01:31 | Not a real trip, the module was due to discarding events and auto power-cycled many time. It was off at ~0:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256633 and was switched on again ~13:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256669. The problem was fixed by using 2nd readout fiber https://atlasop.cern.ch/elisa/display/256668 | |
LBC31 | 2015-04-03 02:00:00 | Not a real trip, the module was due to discarding events and auto power-cycled many time. It was off on ~0:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256633 and was switched on again ~13:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256669. The problem was fixed by using 2nd readout fiber https://atlasop.cern.ch/elisa/display/256668 | |
LBC31 | 2015-04-02 21:01:49 | Not a real trip, power-cycled to fix 100% discarding events https://atlasop.cern.ch/elisa/display/256626. It was switched off ~0:00 on April 03, 2015 https://atlasop.cern.ch/elisa/display/256633 | |
LBC31 | 12:18:09 | Not sure it is real trip, but LBC31 experienced multiple auto power cycle during 2014-04-02 until it turned off https://atlasop.cern.ch/elisa/display/256633 | |
LBC31 | 2015-04-02 00:59:29 | NOT a real trip, power-cycled to fix 99% discarding events https://atlasop.cern.ch/elisa/display/256502 | |
EBA11 | 2015-03-31 23:35:39 | Power cycled https://atlasop.cern.ch/elisa/display/256382 | |
LBC11 | 2015-03-31 10:22:27 | Seem to be power cycled after this “LBC11 seems to be off (at least the ROD link is off). [Run #259427 LB #51]” https://atlasop.cern.ch/elisa/display/256329, two day later report showed it was power recycled frequently https://atlasop.cern.ch/elisa/display/256504 | |
EBC10 | 2015-03-25 11:57:07 | real trip https://atlasop.cern.ch/elisa/display/255607 | |
EBC25 | 2015-03-25 01:45:56 | Power cycled due to lost CAN-bus communication https://atlasop.cern.ch/elisa/display/255559 | |
EBC26 | 2015-03-19 08:08:17 | Real trip https://atlasop.cern.ch/elisa/display/254713 | |
EBC10 | 2015-03-13 23:18:49 | real trip https://atlasop.cern.ch/elisa/display/254196 | |
LBC20 | 2015-03-11 10:14:45 | ||
EBC56 | 2015-03-10 13:23:45 | ||
LBA47 | 2015-03-09 16:00:02 | ||
LBA05 | 2015-03-06 12:56:09 | Not found elog for this trip but later on 3/15 this modules discarded events (67%) and was power recycled by that (https://atlasop.cern.ch/elisa/display/254185). It could be that this trip was because of power-cycled by the same reason |
LVPS trip monitoring program: https://atlaswww.hep.anl.gov/asc/TileCal/EventReporterLVPS/
Module | Trip time | Last installation before trip, box number | Symptom, problem found | DCS image |
EBC56 | 2014-01-16 21:50:26 | tripped by -15V_HV, 5V_HV Vout = 0 at ~21:50 pm but Iout didn't change until ~10:40 pm ebc56_21h_jan16_2014.pdf | ||
LBA53 | 2014-01-14 22:08:17 | 19-NOV-13, 543 | lba53_22h_jan14_2014.pdf |
Also look at Maintenance elog and Operation elog
