Table of Contents
Fast Monte Carlo simulation for Snowmass2013
Here are top-quark “signal” samples generated by requests for Snowmass 2012-2013. Samples are generated using ANL ATLAS Tier3 computer farm based on Arcond/Condor. Details about the Delphes samples for Snowmass are given in this wiki.
- Delphes 3.09. Use Delphes 3 reference http://arxiv.org/abs/1307.6346
- 14 TeV pp collision energy.
- The Snowmass detector geometry See "updateMay8" input cards
- PFlow jets with jet area correction.
- Each sample is generated for <mu>=0,50,140 pileup pileup scenarios (soft events are generated with HERWIG++)
One can view and browser directories with all simulated samples using the ANL Monte Carlo repository. Here is a detailed description:
- HERWIG++ for QCD dijets with pT>650 GeV <fc #FF0000>New</fc>
- HERWIG++ for ttbar with pT>650 GeV (finer CAL segmentation in Phi only)
- HERWIG++ for ttbar with pT>1500 GeV (finer CAL segmentation)
- HERWIG++ for dijets with pT>1500 GeV (finer CAL segmentation)
- Madgraph+Pythia samples <fc #FF0000>New</fc>
- ttbar+1 gamma
- ttbar+2 gamma
- W+2 gamma
- Z+2 gamma
- ttbar+H→ 2 gamma
- Madgraph+Pythia samples for Higgs+ttbar <fc #FF0000>New</fc>
- ttbar→dileptons
- ttbar→lepton+jet
- W+2 gamma
- Z+2 gamma
- Madgraph+Pythia samples for Higgs+ttbar (different channels) <fc #FF0000>New</fc>
- ttWW + up to 1 parton
- ttH, H → tau tau
- tt + ll + up to 2 partons, dilepton invariant mass >= 10 GeV
- ttH, H → ZZ, generic Z decay + up to 1 parton
- ttW + up to 3 partons, generic W decay
- ttH, H→WW + up to 1 parton, generic W decay
Warning: most of the models are at the LO level (HERWIG/Pythia8) or with some NLO corrections (Madgraph). You should apply a k-factor to get a correct normalization (can be a phase-space dependent).
Background samples are discussed in Background Samples Twiki.
Truth MC records
Truth MC record was removed from the Delphes files to reduce file size. Below you can find a repository with truth MC information: signal, signal+pileup (<mu>=50) and signal+pileup(<mu>=140). Pileup particles are included.
Repository with truth MC information <fc #FF0000>New</fc>
Help for analyzers
- How to download link shows an automatic way of copying the ROOT files from this server
- How to analyze link explains how to analyze Delphes3 ROOT files
- How to read Delphes data without ROOT link explains how to analyze Delphes outputs without ROOT (and C++)
- How to generate MC samples link explains how to generate fast simulation events with pileups
- How to access objects link explains how to access jets, leptons, missing ET
Help for Delphes developers
You can add a new deatures to Delphes using this test HEPMC record. Download a HEPMC file with ttbar (>650 GeV, 14 TeV) for Delphes. Get it from here LHC_signal_ttbar650.hepmc.gz. Test Delphes as:
gunzip LHC_signal_ttbar650.hepmc.gz DelphesHepMC examples/delphes_card_ATLAS.tcl LHC_ttbar650.root LHC_signal_ttbar650.hepmc
ATLAS-like detector
Here are the samples for ATLAS-like fast simulation using Delphes 3.03 without pileup removal.
Other samples
Other samples with and without pileup (keeping all final state particles) are discussed here
Snowmass "white" paper based on these samples
The SVN link to the white paper is here. You may need to get the Assembla account and contact me to allow the access.
— Sergei Chekanov 2013/03/06 20:47 — Alexandre Vaniachine 2013/03/06 20:47
