Future detector studies
This page describes a few community tools for Future Collider Physics Studies. Look at the Future Collider Physics Studies meetings
Using SLIC for future detector studies
We use SLIC public software for future collider studies. The instruction how to Run SLIC are attached (created by Jan Strube). The instruction works for e+e- collisions generated by Whizard https://whizard.hepforge.org/
# Setup the environment: source /afs/cern.ch/eng/clic/software/setup.sh # Download a physics file: wget ftp://ftp-lcd.slac.stanford.edu/lcd/ILC/ZPole/stdhep/pythia/pythiaZPolemumu.stdhep # Download a detector: wget http://lcsim.org/detectors/sidloi3.zip mkdir sidloi3 cd sidloi3 unzip ../sidloi3.zip # Convert the compact format to other necessary formats GeomConverter -o lcdd compact.xml sidloi3.lcdd GeomConverter -o heprep compact.xml sidloi3.heprep GeomConverter -o pandora compact.xml sidloi3.pandora cd .. # Run the simulation on 10 events (The crossing angle of the beams is # flexible in our simulation. The physics is from head-on collisions. The # events need to be boosted appropriately such that the outgoing beams go # through the right beam pipe): /afs/cern.ch/eng/clic/software/slic/3.0.1/scripts/slic.sh -x -i pythiaZPolemumu.stdhep -g sidloi3/sidloi3.lcdd -r 10 -m /afs/cern.ch/user/j/jfstrube/public/FCC/defaultILCCrossingAngle.mac -o input.slcio # Run the digitization and tracking: lcsim -D inputFile=input.slcio -D trackingStrategies=/afs/cern.ch/user/j/jfstrube/public/FCC/sidloi3_trackingStrategies.xml -D outputFile=tracking.slcio /afs/cern.ch/user/j/jfstrube/public/FCC/sid_dbd_prePandora_noOverlay.xml # Run the particle flow reconstruction: PandoraFrontend -g sidloi3/sidloi3.pandora -i tracking.slcio -c /afs/cern.ch/user/j/jfstrube/public/FCC/PandoraSettings_sidloi3.xml
You can now analyse the created SLCIO file (“tracking.slcio”) using Python and the FPadSoft software
Truth-level Monte Carlo files
Monte Carlo simulation files with 100 TeV collision events can be downloaded from the HepSim repository. You download, view and process Monte Carlo files as explained here. Also, look at the HepSim wiki.
HCAL studies
— Sergei Chekanov 2014/10/26 23:35
